Varnish For Inkjet Vinyl Printed Signs - Router Forums
post #1 of 3 (permalink) Old 07-31-2018, 07:19 PM Thread Starter
Default Varnish For Inkjet Vinyl Printed Signs
Hello,
I'm wondering if anyone could recommend a product that would work for my application. I'm a landscape designer and I'm making yard signs and also magnetic signs for my truck. The signs will be printed on Epson vinyl. I'm looking for something like the old Bulldog spray varnish product that's no longer available (that is what I used to use and it worked perfectly). Either roll-on or spray....and it should tolerate exposure to sun (protect from UV), and also to some rain on occasion, as well as withstand some mild bending from time to time when I remove the magnetic signage from the truck door so that I can wash my truck. Does anyone know of a product that would work?
Thank you so much.
Nervx is offline
post #2 of 3 (permalink) Old 07-31-2018, 07:47 PM
Hi and welcome N/A. Maybe this was meant to take it's place so that you could use their waterborne varnish over it. http://www.wmbarr.com/ProductFiles/Z...oter%20TDS.pdf
post #3 of 3 (permalink) Old 08-01-2018, 10:12 AM
MEBCWD's Avatar
Welcome to the Router Forums.
This is made for coating vinyl signage. FROG JUICE
MEBCWD is offline
Selling Signs BobbyLee Sign Making 13 02-29-2016 07:10 PM
Spraying Varnish Webwizzkid New Member Introductions 7 10-29-2012 07:33 AM
Wiping Varnish Selection BigJimAK The Finishing Touch 13 09-17-2012 02:49 AM
Treating wooden signs bobmurphy Sign Making 4 06-07-2012 09:48 AM
