Pantograph vs moron - Page 2 - Router Forums
 7Likes
post #11 of 12 (permalink) Old 08-23-2018, 09:53 AM
MEBCWD's Avatar
Part of the problem could be trying to climb cut instead of feeding the bit into the cut. I don't see where it would just stall and not cut but it could make it harder to cut and cause jumping or be hard to control.
It would help if we had pictures of the bit and the cuts that were made in the wood. One other thought would be if the Arms of the pantograph are binding and causing the hard to operate problems.
DaninVan and Herb Stoops like this.
MEBCWD is offline
post #12 of 12 (permalink) Old 08-23-2018, 06:35 PM
roofner's Avatar
First Name: Gary
I received my pantograph could not assemble bolts would not go in. . The one bolt jammed and would not go on or back off sent back sending another.
roofner is offline
Milescraft Pantograph BigM Sign Making 16 12-09-2014 08:20 AM
Pantograph Router saramererid General Routing 4 07-27-2011 09:49 PM
Assembling Milescraft 3D Router Pantograph no1texan General Routing 1 04-30-2011 11:33 AM
router pantograph pjcas Starting Off 2 01-26-2009 12:53 AM
Craftsman Deluxe Router Pantograph wayoutwest General Routing 1 09-24-2007 06:17 AM
