Shadow Box - Page 2 - Router Forums
 30Likes
post #11 of 20 (permalink) Old 10-11-2018, 10:55 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Well, the box is made.....still have some finish sanding to complete. Then I'm going to apply Teak Oil; per the customer's request. I'll post finished pictures when I finish it on Saturday. Here a few pics of the actual shadow box.....the wood is Poplar.
Marco, MEBCWD, grbrico and 4 others like this.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #12 of 20 (permalink) Old 10-12-2018, 01:11 AM
I Like that Frank. Good job beveling the perimeter.
Frankj3 likes this.
Herb Stoops is online now
post #13 of 20 (permalink) Old 10-12-2018, 10:39 AM
That really turned out well. Looks like you learned a lot from doing the trial run first. That is really handsome.
Frankj3 likes this.
post #14 of 20 (permalink) Old 10-12-2018, 04:58 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Tom, I am really glad I did because it was a teaching/learning experience. I hope to finish it late tonight or early in the morning. The customer's birthday is tomorrow and he'd like to have by then if at all possible. So it's off to the shop I go......
Frank
Frankj3 is offline
post #15 of 20 (permalink) Old 10-12-2018, 08:56 PM
hawkeye10's Avatar
First Name: Don
Looks very good. Thank goodness for the digital gauge, I had to do a lot of measuring and test cuts to get a tight fitting miter. Exact matching of opposite side piece lengths is essential, or 45 degree accuracy is moot.
Attachment 360403
I finally bought a Grizzly miter trimmer, see pix. and after that all the rough edges of the miter joint disappeared. CAUTION: the griz is wicked sharp and I cut my finger on it when I unpacked it. The miter trimmer has two wings to hold the pieces, with a stop block on it. However, the wings are really not very well secured and I no longer use them. I match lengths by putting the pieces back to back. Your fingers can detect differences of a couple of thousandths, so this is pretty exact. I cut very precise 45s, usually on my table saw with a Rockler sled. I cut about 1/8th inch long and use the trimmer to slice about 1/16th off each end, with careful length matching on the second piece. When I trial fit, there are rarely any gaps, and the edges are knife edge perfect.
From time to time, I find a bit of a twist or some other irregularity shows up as a mis-fit. If it's not too bad, I use my secret weapon, Tember Mate, which is a wonderful filler that takes stain and finish just like the wood itself. You buy it to match your wood species. It is extremely fine textured and fills even the tiniest gap. It stays put, doesn't shrink and sands smooth. It is an Aussie product available on Amazon. See pix below.
If there is a slight twist or mismatch after glueup, I will sand it down using a shaped sanding block (Rockler), which greatly eases sanding even the most complex shape. I also use 3M Sandblaster Pro, flexible sanding medium, rarely more than 220 grit. The grit lasts forever and takes only a few strokes to produce a baby smooth surface. It also allows rapid evening out of mis-fit joints. I would not use regular sandpaper for this again.
I know what you mean about not wanting to use the good stuff first, which is why I posted this. Fitting mitered corners is equal parts art and craft, and this is how I save the day when there's a glitch.
Tom, I really like Timber Mate and I have used it for a while.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #16 of 20 (permalink) Old 04-22-2020, 01:53 AM
First Name: Randy
Attachment 360403
Yes I know how old this topic is but I have just seen it. I have seen one of those Tom, just never seen one being used. Neat tool. Do they work well and stay sharp on hardwoods?
ranman is offline
post #17 of 20 (permalink) Old 04-22-2020, 01:57 AM
no worries on how old a thread is...
who says the old ones gotta stay buried...
content revival is always a good thing...
post #18 of 20 (permalink) Old 04-22-2020, 02:08 AM
I have a Lion Knife...
they work better than very well and they do stay sharp...
I used mine to make this medallion, china cab and writing desk/chair...
marecat3, TenGees and Oscar36 like this.
post #19 of 20 (permalink) Old 05-18-2020, 09:56 PM
crisp corners
senorwanderer is offline
post #20 of 20 (permalink) Old 05-18-2020, 10:34 PM
dman2's Avatar
First Name: Dave
TomDesertRat and others)
Wow! Thanks so much. As a retired person doing what I have always loved, but never did much of it in my younger years, thank you for sharing your life-learned info. I never would have known this!
dman2 is offline
Shadow box tdog Show N' Tell 9 11-13-2012 06:09 AM
Shadow Box Jerry Bowen Tools and Woodworking 0 06-22-2012 08:12 AM
Shadow Box to Hide ugly Electric panel box roxanne562001 Show N' Tell 1 03-09-2012 05:40 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
Little shadow box Fourleftpaws Show N' Tell 9 02-09-2009 04:47 PM
