Shadow Box - Router Forums
 30Likes
post #1 of 20 (permalink) Old 09-26-2018, 10:33 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Default Shadow Box
Admins......please move this post if it is not supposed to be in this section.
I've been working on a shadow box for a customer.....one of the projects I can show progress pics of.
I've been making a practice box before I make his actual box. The board he wants me to use for his box is Poplar....not a cheap wood but not the most expensive wood either. Still, it cost enough that I decided to buy a piece of pine to use for my practice box.
I found out the 45 setting on my saw is actually a 43.5 which does not make pretty, or tight fitting 45 corners......and that's why I used a practice board first. So tonight I used my digital indicator and found the true 45 setting. Tomorrow I will re-cut the bevels to see if I can get a better fit on 45 bevels.
I like the shape of the frame face. The sides come up to a 45 bevel, then roll into a 1/2" radius and end up sweeping into the glass. Another first for me with this design.....and another reason for making a practice box first.
Nothing has been sanded.....and probably won't be on this practice box.....so don't be too critical yet.....but it will be sanded and nicely blended in (and HOPEFULLY none of the seams will be visible) when I cut the Poplar boards.
Here are some pics of the practice box. I'll post pics of the finished box when it's ready to be delivered.
CharleyL, MEBCWD, Gaffboat and 7 others like this.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #2 of 20 (permalink) Old 09-27-2018, 07:43 AM
TenGees's Avatar
First Name: Paul
Looking good so far, Frank.
Frankj3 likes this.
TenGees is offline
post #3 of 20 (permalink) Old 09-27-2018, 07:58 AM
First Name: mary
looking good
Frankj3 likes this.
marecat3 is offline
post #4 of 20 (permalink) Old 09-27-2018, 08:53 AM
Gaffboat's Avatar
First Name: Oliver
I like that, Frank. The bevel on the face frame is a nice touch.
Frankj3 likes this.
Gaffboat is offline
post #5 of 20 (permalink) Old 09-27-2018, 08:58 AM
Bushwhacker's Avatar
First Name: David
Good job there Frank. Hope you are doing well. Haven't heard from you in a while.
David
Frankj3 likes this.
When the enemy is in range, so are you.
Bushwhacker is offline
post #6 of 20 (permalink) Old 09-27-2018, 10:35 AM
MEBCWD's Avatar
Frank everything looks good so far. I'm sure the project will turn out good with the testing you are doing. I also agree that the profile you are using on the face edge works well for the project.
As you have found it is best to check settings with accurate measuring instruments and not depend on the built in quick stops on the power tools.
Frankj3 likes this.
MEBCWD is offline
post #7 of 20 (permalink) Old 09-27-2018, 10:55 AM
Looks very good. Thank goodness for the digital gauge, I had to do a lot of measuring and test cuts to get a tight fitting miter. Exact matching of opposite side piece lengths is essential, or 45 degree accuracy is moot.
I finally bought a Grizzly miter trimmer, see pix. and after that all the rough edges of the miter joint disappeared. CAUTION: the griz is wicked sharp and I cut my finger on it when I unpacked it. The miter trimmer has two wings to hold the pieces, with a stop block on it. However, the wings are really not very well secured and I no longer use them. I match lengths by putting the pieces back to back. Your fingers can detect differences of a couple of thousandths, so this is pretty exact. I cut very precise 45s, usually on my table saw with a Rockler sled. I cut about 1/8th inch long and use the trimmer to slice about 1/16th off each end, with careful length matching on the second piece. When I trial fit, there are rarely any gaps, and the edges are knife edge perfect.
From time to time, I find a bit of a twist or some other irregularity shows up as a mis-fit. If it's not too bad, I use my secret weapon, Tember Mate, which is a wonderful filler that takes stain and finish just like the wood itself. You buy it to match your wood species. It is extremely fine textured and fills even the tiniest gap. It stays put, doesn't shrink and sands smooth. It is an Aussie product available on Amazon. See pix below.
If there is a slight twist or mismatch after glueup, I will sand it down using a shaped sanding block (Rockler), which greatly eases sanding even the most complex shape. I also use 3M Sandblaster Pro, flexible sanding medium, rarely more than 220 grit. The grit lasts forever and takes only a few strokes to produce a baby smooth surface. It also allows rapid evening out of mis-fit joints. I would not use regular sandpaper for this again.
I know what you mean about not wanting to use the good stuff first, which is why I posted this. Fitting mitered corners is equal parts art and craft, and this is how I save the day when there's a glitch.
Frankj3 likes this.
post #8 of 20 (permalink) Old 09-27-2018, 11:10 AM
The design is good Frank. Part of the problem with the miters might be the blade you are using. The angle doesn't look that bad but it looks like the blade may have been pulled sideways when angling across the grain. I had that problem once and solved it using blade stabilizers. The stabilizers made the blade much more rigid so that it didn't tend to wander back and forth when angling across the grain.
Frankj3 likes this.
post #9 of 20 (permalink) Old 09-27-2018, 03:14 PM
First Name: Larry
Looking good Frank. I am sure it will turn out just like you expect it in the end.
Frankj3 likes this.
Knot working is offline
post #10 of 20 (permalink) Old 09-27-2018, 07:41 PM Thread Starter
Frankj3's Avatar
First Name: Frank
David
David, I have been really busy at my day job. I'm retiring mid-December and my customers are trying to get all they can from me before then. LOL We need to do another lunch or supper gathering.....soon!
Frank
Frankj3 is offline
Shadow box tdog Show N' Tell 9 11-13-2012 06:09 AM
Shadow Box Jerry Bowen Tools and Woodworking 0 06-22-2012 08:12 AM
Shadow Box to Hide ugly Electric panel box roxanne562001 Show N' Tell 1 03-09-2012 05:40 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
Little shadow box Fourleftpaws Show N' Tell 9 02-09-2009 04:47 PM
