Free Hand Routing help - Router Forums
post #1 of 4 (permalink) Old 03-25-2013, 08:06 PM Thread Starter
Default Free Hand Routing help
Im currently new to the whole free hand routing thing, but i know after some practice i would be able to get it down. Now my question pertains to the image i have attached to this post and im wondering what type of router and bit i should use to carve something like this out? I want to be able to carve it completely through the wood so i can see throught it. I going to make a table with this and going to have green led lights light up the lettering from the inside through probably some plexi glass of some sort.
thanks for any help!
Name:	monster energy.jpg
rocker2333 is offline
post #2 of 4 (permalink) Old 03-26-2013, 05:25 PM
Hi N/a and welcome to the forum.
I know this is a router forum, but I would be looking at a scroll saw?
Sydney, Australia
jw2170 is offline
post #3 of 4 (permalink) Old 03-26-2013, 07:55 PM
Welcome to the forum n/a. James may be right depending on how fine you want the points on the pattern to be. About the smallest bit I would try that with would be a 1/4" diameter, preferably an upcut spiral. The lines are uneven enough that you could do it freehand and would probably look good even if you don't perfectly match the lines on the pattern. Probably the best way to do it (scroll saw, jig saw, or router) would be to have that blown up to the size you want at a copy shop and then glue it down with spray glue or water soluble glue.
post #4 of 4 (permalink) Old 05-23-2013, 05:27 PM
Stan Richardson's Avatar
First Name: Stan
James,
I also would have said a scroll saw :-)
Stan Richardson is offline
So, what anti virus protection do you use? andrewmoquin Lobby 38 01-24-2013 01:40 PM
FREE FREE FREE DVDs Bob N The Bargain Bin 25 01-28-2009 10:38 PM
