Plunge Router - Router Forums
post #1 of 11 (permalink) Old 09-27-2013, 04:44 PM Thread Starter
tvman44's Avatar
First Name: Bob
Default Plunge Router
Just about to take the plunge and get a plunge router primarily for trying my hand at signs, I have pretty much made up my mind I want a Bosch 1617EVSPK. My biggest concern is if this is too big for sign making? I know there are smaller available and they would be easier to handle but I want to be able to use it for other things especially if I end up not liking signs it would be big enough for doing other task. I believe it weights in at 19lbs, but I am a big boy 6' 3 1/2" 245lbs. I have already made up a list of accessories I want with the 1617. What ever I end up with it has to be a plunge router.
Bob
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #2 of 11 (permalink) Old 09-27-2013, 05:55 PM
First Name: Duane
The shipping weight for the kit may be 19lbs, the router and plunge base alone shouldn't be!
Dmeadows is offline
post #3 of 11 (permalink) Old 09-27-2013, 07:04 PM Thread Starter
tvman44's Avatar
First Name: Bob
I had not thought about that, 2 bases when you can only use one at a time that has to reduce by a couple of pounds + the rest of the kit & case.
Papa Bob
tvman44 is offline
post #4 of 11 (permalink) Old 09-28-2013, 08:11 AM
First Name: Buck
I think Duane is correct. I doubt very much it is 20 pounds ..... at least I hope not. I don't know anyone, regardless of their size, that would want to wrestle a router of that size.
Buck
BOjr is offline
post #5 of 11 (permalink) Old 09-28-2013, 11:14 AM
First Name: Phillip
I use the plunge base regularly on my 1617. It's definitely not 20 pounds.
You will find that the router is nimble enough for sign making and large enough to use large cutters in the table.
To change the world, change your mind.
phillipdanbury is offline
post #6 of 11 (permalink) Old 09-28-2013, 07:47 PM
The heaviest router is the PC 7538 at 18-1/2 lbs, the 1617 is a feather weight compared to it.
post #7 of 11 (permalink) Old 09-29-2013, 12:34 PM
First Name: Doug
The 1617 with fixed base is 7.7 pounds,
the Plunge base alone is 4.6 pounds
After you swap bases it should be around 10 Lbs.
mrk10989 is offline
post #8 of 11 (permalink) Old 09-29-2013, 03:56 PM
Hi, Bob; I don't know what my Bosch 1619 plunge router weighs but I have no real problem with using it for mortising on the sides of vertical posts. Must be a similar weight to the 1617? On flat horizontal surfaces the weight isn't really an issue as the work surface is supporting it.
(I'm 6' 185lbs.)
DaninVan is online now
post #9 of 11 (permalink) Old 10-13-2013, 03:14 PM Thread Starter
tvman44's Avatar
First Name: Bob
Well I bit the bullet and got the Bosch 1617EVSPK, RA1173AT dust collection accessories, VAC005 vacuum hose, RA1126 quick release adapter, RA1100 adapter for PC style bushings, RA1151 Centering Pin & Cone, RA1054 Deluxe Router Edge Guide. Have not done much except to try a free hand sign and love the dust collection. It did not leave a mess all over the shop.
Papa Bob
tvman44 is offline
post #10 of 11 (permalink) Old 10-13-2013, 07:45 PM
OutoftheWoodwork's Avatar
First Name: Barb
...And Mike would know. He's tried and had more routers in his garage than I've
seen in stores, and that's a lot
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
Bosch plunge router base problem gwizz General Routing 20 03-16-2017 07:02 PM
Newbie in using a Router..... Andron General Routing 6 03-20-2013 02:20 PM
Plunge router mounting on table Bram Table-mounted Routing 6 04-04-2006 03:22 PM
