Painting question? - Router Forums
post #1 of 8 (permalink) Old 12-10-2013, 10:53 AM Thread Starter
tvman44's Avatar
First Name: Bob
Default Painting question?
After painting to fill in letters on a sign what do most of you do, plane the surface or sand the surface to remove any paint that is not wanted? Hope I made mymself clear. The paint seems to clog up sanding belts pretty fast and I don't have a planer, I do have a 6" jointer which should work for signs up to 6" wide. I can't seem to keep all the paint in the cuts.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #2 of 8 (permalink) Old 12-10-2013, 12:24 PM
First Name: Brad
You need the paint to dry longer if it's clogging paper up. I usually belt sand. I don't want the paint on the cutters or in the dust collection.
thedude306 is offline
post #3 of 8 (permalink) Old 12-10-2013, 12:45 PM
jeepered's Avatar
First Name: Ed
Bob,
I have been very successful with using two incompatible paints during the finishing stage. I seal and finish the project with a clear lacquer finish and burnish it to a satisfactory sheen or gloss. After this I fill the letters' recesses with an enamel paint, which is incompatible with lacquer thinner based paints (like oil and water) and let it dry over night. The following morning the enamel paint is only partially dry and is still dissolvable in paint thinner. I wrap a layer of "T-shirt" material, moderately dampened with paint thinner, tightly around my index finger and gently and carefully remove any enamel paint that I may have slopped on the surface of the project by rubbing the edges of the letters. Of course, if you're going to stain your project, do so before you apply the lacquer finish. Also, don't attempt to remove too much of the enamel paint's overflow at one time. Regularly rotate the T-shirt material on your finger so that you are working with a clean spot most of the time. This method leaves sharp, clean lines of the letters. I don't suggest putting a final coat of lacquer over the project as a final step. This may crinkle or lift the enamel paint in the letters. You can put enamel paint on lacquer but you can't put lacquer on enamel paints. Try this method on a sample letter and let me know what you think of it.
Thanks,
ED
The very next time you have the need for a truly sensual experience, place your hand on a piece of finely worked wood.
jeepered is offline
post #4 of 8 (permalink) Old 12-10-2013, 08:54 PM
Hi Bob - I've been planning them with a router and jig using a bit like #2706 here:
<img src="/v/vspfiles/assets/images/brands/magnatelogo_small.gif">Surface Planing ( Bottom Cleaning ) Router Bit , 2 Flute Carbide Tipped
A smaller bit will work equally well. A 1-1/2" bit is significantly cheaper.
The jig is just a shallow box, deeper than the sign and a few inches longer and wider. This allows the sign to be wedged firmly about the center of the box. I made a sub base for the router that is long enough to span the short dimension of the box plus enough to allow the router bit reach both edges of the sign. The router rides on the top edge of the box sides and I use the micro depth control on the router.
Paint can really gum up the router bits but they will clean up pretty good. I'm pretty sure it would do a number on planner/jointer knives though. I usually spray paint mine though so I am likely removing more paint than you would be.
John Schaben
jschaben is offline
post #5 of 8 (permalink) Old 12-11-2013, 06:21 AM
Iceman567's Avatar
First Name: Ted
I gave up on the spray paint, spray inks long time ago. I use acrylic paints now. No smell, no gummed up sanding belts, dries quick, many more colors available. No need to 'pre-seal' the letters prior to painting, the acrylic doesn't bleed.
Any paint that ends up on the surface, a quick hit with the random orbital sander and it's done.
Name:	ready to sand.jpg
Name:	bike enlarged.jpg
The trouble with quotes on the internet is that you never know if they are genuine. - Abraham Lincoln
Iceman567 is offline
post #6 of 8 (permalink) Old 12-11-2013, 07:38 AM
First Name: Andrew
Send a message via Skype™ to Roodog
Many years ago I saw a woodworker do exactly what you are after. He used a pantographic router to carve the letters, which give identical, even letters. Then he used spraypaint to get into the letters, a reversed vacuum cleaner to ensure the paint was dry, and then used a sander to clean off any unwanted paint. I have used this method myself, and it works very well. You just have to make sure that the paint is totally dry. Good luck and happy painting.
Roodog is offline
post #7 of 8 (permalink) Old 12-11-2013, 01:56 PM
rwl7532's Avatar
First Name: Ralph
Twice through the jointer (after flipping the board) should give you up to 12".
Maybe a bit of sanding still with that method.
As the others stated, let the paint dry thoroughly.
Or a good excuse to buy that planer you want.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #8 of 8 (permalink) Old 01-06-2014, 09:31 AM
L Town Graphics's Avatar
What he said
"the last person that was perfect was crucified"
Find all of my work both wood and vinyl on Facebook
-coming soon- www.ltowngraphics.com
L Town Graphics is offline
Question About This Forum Jerry Bowen Tools and Woodworking 4 03-30-2012 09:46 AM
Painting Pressure treated wood kp91 The Finishing Touch 9 09-05-2008 10:26 PM
Rookie here, got a question wyatt earp New Member Introductions 6 07-18-2008 08:33 AM
