First Sign and used the Copycarver - Router Forums
post #1 of 13 (permalink) Old 02-21-2014, 01:10 PM Thread Starter
Default First Sign and used the Copycarver
This is my first sign and I made it using my homemade Copycarver.
I made a pattern out of 1/4 luan and used luan scraps to raise the logo and lettering.
There are mistakes, and I learned a lot making this first sign.
I initially used a 1/8 bit to outline all the raised area and then used a 1/2 inch bit to do the rest of the relief work. One thing I will change for next time is, I will do my routing in layers rather than hogging it all out at one time.
Another change is that I will wax my pattern to make sure that the follower glides smoothly over the surface.
Using a hot glue gun to attach the letters was a good thing because I could set one letter with hot glue, and almost immediately press a spacer nest to that letter to set the next.
Here are a couple pictures.
flockshot is offline
post #2 of 13 (permalink) Old 02-21-2014, 02:23 PM
Semipro's Avatar
First Name: John_*
Looks like that came out well,
how long does that take to do a sign that size
Semipro is offline
post #3 of 13 (permalink) Old 02-21-2014, 03:19 PM Thread Starter
The actual routing took less than an hour. The template on the other hand took me a couple days. All I had to work with was a 1 x 1 inch picture of the logo I got off the Cinch Gaming - eSports Tournament Game Controllers website. When you blow something that is so small up to actual size it is very fuzzy and cannot be used as a pattern.
This sign is for my son, so labor was no issue.
post #4 of 13 (permalink) Old 02-21-2014, 04:36 PM
Great result, John.
Sydney, Australia
jw2170 is offline
post #5 of 13 (permalink) Old 02-21-2014, 07:22 PM
Dejure's Avatar
First Name: Kelly
The sign indicates your effort to build the machine was well worth while. That said, I like the under-cut effect on the pattern too.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #6 of 13 (permalink) Old 02-21-2014, 07:54 PM Thread Starter
It is interesting you would mention that. The undercut look is from me gluing blocks under the pattern to raise it up, but I am thinking that it would also be interesting to try a dovetail bit in the router to undercut the finished sign.
post #7 of 13 (permalink) Old 02-21-2014, 08:05 PM
JOAT's Avatar
First Name: Theo
Well, I think the whole project came out quite nicely, sign, copy carver, et al. Way to go.
JOAT is offline
post #8 of 13 (permalink) Old 02-21-2014, 11:00 PM
old55's Avatar
First Name: Ross
Looks good John.
Ross,
old55 is offline
post #9 of 13 (permalink) Old 02-22-2014, 07:26 AM
Olde Bloke's Avatar
First Name: Russ
You've got what I need, John.... MOTIVATION!
Looks really good - Well done!!
Olde Bloke is offline
post #10 of 13 (permalink) Old 02-22-2014, 07:54 AM
OutoftheWoodwork's Avatar
First Name: Barb
Nice job, John! Looks Amazing!
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
