Surfacing boards? - Router Forums
post #1 of 7 (permalink) Old 07-06-2014, 07:34 PM Thread Starter
tvman44's Avatar
First Name: Bob
Default Surfacing boards?
Looked at a couple of Dave's u tube videos on line and he mentioned using cedar fence boards and surfacing the board before making the sign but I cannot find where or how he surfaces the boards. Anyone using cedar fence boards for signs, and if so how do you prepare the boards for making a sign? I know he prefers sanding the board after carving the sign and painting.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #2 of 7 (permalink) Old 07-06-2014, 11:20 PM
I would use a sled or skis if I were using a router.
post #3 of 7 (permalink) Old 07-07-2014, 01:25 AM
Whatcher lookin' for is one of these puppies, Bob...
Vintage Sears Craftsman Accra Radial ARM SAW Rotary Surfacing Planner Head 2951 | eBay
Or a hand plane.
DaninVan is online now
post #4 of 7 (permalink) Old 07-07-2014, 03:05 AM
Hi Bob.
Dave most likely uses a thickness planer to surface the boards.
A lot of background work take place before the cameras are turned on with some of those Youtube videos.
Boards up to 10" wide, I run through the thickness planer.
Sydney, Australia
jw2170 is offline
post #5 of 7 (permalink) Old 07-07-2014, 07:46 AM
L Town Graphics's Avatar
I use cedar all of the time for outdoor signs (on island time is made on cedar). But to answer your question I use a thickness planer like james above mentioned. Cedar from what I have seen tends to cup so planing is necessary to have a flat surface
"the last person that was perfect was crucified"
Find all of my work both wood and vinyl on Facebook
-coming soon- www.ltowngraphics.com
L Town Graphics is offline
post #6 of 7 (permalink) Old 07-14-2014, 09:48 AM
First Name: Scott
Hey Bob, I have watched Dave's videos also and will start using the cedar fencing boards soon. I think he uses a Ryobi Belt Sander to get the boards ready to be routered. The boards are very thin and if I remember correctly he uses 80 grit and 120 grit. He cross sands the back of the board and sands with the grain on the front to get the smooth finish. Once he is done with the routering then he uses 30 grit to get the ink paint off then uses 80 then 120 to finish the sign. I heard him say in the video people were having trouble because the sander was taking too much wood off. So I think you need to use very light pressure when sanding.
itpcpro is offline
post #7 of 7 (permalink) Old 07-15-2014, 11:12 AM
Bryan Rocker's Avatar
First Name: Bryan
A thickness planer would be the best bet but you could also use a wide belt sander. If you don't have either, check out your local hardwood dealer, they usually have or know someone who will do either for a small fee.
Bryan Rocker is offline
Cutting Boards Barry747 Wood Species 8 10-09-2014 05:56 AM
Cutting Boards Christmas Gifts oldwoodenshoe Show N' Tell 15 12-19-2013 11:32 PM
Planing with a Router Gilbear Portable Routing 51 05-17-2012 04:40 PM
First Cutting Boards Soapdish Show N' Tell 3 02-03-2010 10:35 AM
Jointing long boards Jtomwoods Table-mounted Routing 8 05-25-2008 09:05 PM
