My first (test) freehand sign... - Router Forums
post #1 of 15 (permalink) Old 07-10-2014, 11:23 PM Thread Starter
Cool My first (test) freehand sign...
As I have mentioned before, I had been commissioned by the Men's Shed to make a sign for one of the members.
I have looked at various ways to make the sign and the way I would like to go with was using the router skis with the work piece ( a piece of Jarrah) locked in a jig.
Another way was to cut the sign freehand using a smaller Ozito router.
The outline of the letters will be cut using a CNC laser cutter that the shed has acquired.
I decide to make a test cut on some scrap ply today using the Ozito router and a 7mm straight cutter.
The depth was set and locked, so, in use, it acted like a fixed base router.
Here are some photos of the result....
Sydney, Australia
jw2170 is offline
post #2 of 15 (permalink) Old 07-10-2014, 11:48 PM
Gaffboat's Avatar
First Name: Oliver
Well clearly your method worked very well. It looks great. I'm very envious of having access to a laser cutter.
Gaffboat is offline
post #3 of 15 (permalink) Old 07-11-2014, 04:42 AM
carl.p's Avatar
Country: South Africa
First Name: carl
Default first test
Hi James very good for first time some hidden talents showing there. regards carl
Classical music is food for the mind and soul.
carl.p is offline
post #4 of 15 (permalink) Old 07-11-2014, 07:09 AM
BCK
First Name: BC
couldn't the laser been used to do it all??? or is that possible...know nothing of laser cutters..nice to have finished outter edge pre-done..steady hand and stay inside the lines..like coloring book as a child....good job though..
http://www.natures-lifestyles-digest.com/smf
above [link]site has: outdoors type things from fishing, hunting, boating, hiking, to living off grid, gardening from veggies to flowers etc, recipes from home cooking to smokers, hobbies, home remedies, to making your own soaps etc..live members chat area.. and more...all is welcome to browse or join..
BCK is offline
post #5 of 15 (permalink) Old 07-11-2014, 08:30 AM
RainMan 2.0's Avatar
I have an 80 watt laser and in mdf at max it's about 2mm deep vectoring , so no . Great for tracing the outline though . An 80 watt will cut threw 6mm plexiglass pretty much perfectly though, just not wood . I can cut threw that thin wood used by model aircraft builders which is a bonus if you've ever cut out all those parts . It's not balsa anymore , it's something much harder.
James are you chiseling the corners as I'm not seeing a radius? Great job
RainMan 2.0 is offline
post #6 of 15 (permalink) Old 07-11-2014, 08:33 AM
James to bad you didn't post a video of some of this as I'd be interested to see it as it's made . Not understanding how you stay in the lines so well and straightaways
post #7 of 15 (permalink) Old 07-11-2014, 08:38 AM
Country: Mexico
First Name: Joseph Anthony
Thumbs up
Yes James, or at least some pics with the skis doing the work.
RÖENTGEEP is offline
post #8 of 15 (permalink) Old 07-11-2014, 08:53 AM
Nice work James.
post #9 of 15 (permalink) Old 07-11-2014, 09:48 AM
Country: Brazil
First Name: sid
Very nice work! Sid
ksidwy is offline
post #10 of 15 (permalink) Old 07-11-2014, 11:57 PM
OutoftheWoodwork's Avatar
First Name: Barb
Talking
Nice job James! Especially block lettering on the first freehand! May I make a suggestion? Use a v-bit to outline, and use the straight as a clean-out. I think you'll like the effect, as most signs made use the angle, with the exception of recessed signs (or when the letters are raised. I forget the term.) I use an Amana triple edge flute bit (roughly $65 here) and use my 1/16 for clean out or my 1/8 for larger areas
I'm really impressed, because block lettering is a bugger. You took your time and had the patience. Hats off to you, my friend
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
Router Bit Test / Comparison Robert Brown Router Bits - Types and Usage 3 08-04-2010 09:07 AM
What wood to use for test cuts cgreene Table-mounted Routing 9 01-30-2010 03:04 PM
