Custom Router base - Router Forums
post #1 of 3 (permalink) Old 09-26-2014, 01:05 PM Thread Starter
First Name: Scott
Default Custom Router base
Anybody else make their own custom trim router base.
itpcpro is offline
post #2 of 3 (permalink) Old 09-26-2014, 03:24 PM
Honored Member
First Name: pat
For that one and 25 others.
Quillman is offline
post #3 of 3 (permalink) Old 09-26-2014, 10:00 PM Thread Starter
First Name: Scott
I figured I would get someone who has had to do this. I ended up using lexan. Worked out well for my first try. Learned a lot after trying to get the holes to line up. It does flex a little which personally I do like as it allows me to pull up on the base while allowing the other side to stay flat. If I have an image that has a point I can slowly lower the router to start the cut. All in all the base does a great job allowing me to control the router.
itpcpro is offline
Bosch 1617 router base problem bill kay General Routing 35 05-30-2016 08:39 AM
Triton Router Base Plate garbo.hunter Triton 10 08-09-2013 09:00 AM
Model 320.17542 and table routing 46_trap Table-mounted Routing 44 10-16-2011 01:40 PM
Dremel Tool Precision Router Base BigJimAK Tools and Woodworking 7 02-08-2010 02:51 AM
