Sign making observations... - Router Forums
post #1 of 8 (permalink) Old 02-11-2015, 06:05 AM Thread Starter
First Name: Ron
Default Sign making observations...
not new to routing, but new to sign making...did some study and experimenting regarding transfering text to wood.
Tried carbon paper-too laborious, tried the laser printer/mirror image/laquer thinner/mirror image wipe method-not enough transferred. Penciled from cut out craft shop letters, fine, laborious, and limited fonts available.
Then happened on the inkjet printer/avery label backing sheet/mirror image/burnish method...viola, success! A clear, clean, quick eze process.
bonus, if your inkjet has a mirror image setting (many do), you can create your letters, images, whatever in any program, i.e. ms word, publisher and even pictures.
I did download and have used Inkscape (free program) for more options (mirror image if your printer doesn't have that option), but I am more familiar with msoffice, programs and ease of use, plus Word has a good variety of fonts.
Just thought I'd share, likely redundant to you experienced folks.
Best,
Ron
(note, using a DW618 w/vac attachment, PW sub base, MLCS veining and other bits)
(using the cedar dog ear fence pickets approx 1/2 x 6", great for many signs, and very inexpensive about $2.50 @ HD -4-5' length)
rpludwig is offline
post #2 of 8 (permalink) Old 02-11-2015, 06:13 AM
CharleyL's Avatar
First Name: Charley
There's also "Applique Film". It's available through most Stationery stores. It's an 8.5 X 11" sheet of plastic material that you can run through a laser or inkjet printer and it has a peel- and-stick backing that is easily removed afterward. I use it for scroll saw and power carving work.
Charley
Central North Carolina
CharleyL is online now
post #3 of 8 (permalink) Old 02-11-2015, 06:16 AM
tvman44's Avatar
First Name: Bob
Can the backing sheets be purchased alone or do you have to buy labels and discard them? I read about this method awhile back but have yet to try it because I don't have any backing sheets yet. Hate to go buy labels and discard them for the backing sheets just to try the method.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #4 of 8 (permalink) Old 02-11-2015, 06:18 AM
tvman44's Avatar
First Name: Bob
Do you use the "Applique Film" or the backing sheet for the transfer?
Papa Bob
tvman44 is offline
post #5 of 8 (permalink) Old 02-11-2015, 06:34 AM
N'awlins77's Avatar
First Name: Lee
In Goggling that process, I also found this, which could come in handy in large signs.
Block Posters - Create large wall posters from any image for free! - You can print an image over several sheets of paper, to create a large sign.
And Bob, I don't think you can purchase just the wax papered backing. Which is no problem for me, as I once bought a box of Avery adhesive sheets that I thought was just the little tags, and ended up being full sheets. Or I bought them for a one time project. Either way, I've never used them since --- till now!!
N'awlins77 is offline
post #6 of 8 (permalink) Old 02-12-2015, 08:22 AM
First Name: Gary
Charley, Does Staples have it? What is it called?
gmercer_48083 is online now
post #7 of 8 (permalink) Old 02-12-2015, 08:56 AM
First Name: Scott
I am not sure how good it works but i have also heard you can use wax paper with the ink jet and get the same results. I personally use the LaserJet mirror image transfer with acetone to get my image on the boards. I did fined that the smoother the surface the better the image.
How to print pictures on wood. Wax Paper transfer. | The Art of Doing Stuff
itpcpro is offline
post #8 of 8 (permalink) Old 02-12-2015, 10:46 AM
rwl7532's Avatar
First Name: Ralph
Default Pounce patterns for sign making
Google pounce pattern.
Shops that make vinyl lettering can also make a paper pounce pattern.
I used charcoal as in my pounce bag. (yeah messy).
The attached picture of the restaurant's doors I did 10 times using the same paper pounce pattern.
The floral pattern on french doors was done onsite. One day of pouncing and cutting. One day of sandblasting.
The mirror image of the floral pattern was just flipping the paper pounce pattern over and pouncing the other side.
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is online now
Sign making mashnee New Member Introductions 8 04-29-2016 06:52 PM
Sign making Idea's? RouteringRookie Starting Off 9 04-28-2016 01:28 PM
Sign Making Router Bits and Letter Templates Auggie General Routing 4 04-20-2016 06:37 PM
Sign Making Design Software airborne152 Sign Making 10 01-04-2014 05:59 PM
Making SMALL sign and need advice? JohnnyB60 Sign Making 27 06-24-2013 10:19 PM
