The Old Rugged Cross - Router Forums
post #1 of 7 (permalink) Old 02-21-2015, 04:14 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Default The Old Rugged Cross
I made this cross as a surprise for my sister. I still need to clear coat it before giving it to her.
It took me longer to make my jig than it did to make the cross.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #2 of 7 (permalink) Old 02-21-2015, 04:44 PM
kp91's Avatar
First Name: Doug
That is going to look great finished. The background grain is very attractive.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 7 (permalink) Old 02-21-2015, 09:17 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Here's a picture of the Old Rugged Cross with 2 coats of clear acrylic.
The grain "popped" more than I expected.
Frank
Frankj3 is offline
post #4 of 7 (permalink) Old 02-22-2015, 07:00 AM
First Name: Graham
Hi Frank,
Very nice job.
Cheers Graham.
Matador58 is offline
post #5 of 7 (permalink) Old 02-22-2015, 01:20 PM
First Name: Ray
Wow Frank, both the cross and your jig look GREAT!!!
Copyright©2015 A.D. (Anno Domini, Latin for "in the year of our Lord") e.g., historical FACT!
Life is a comedy for those who think, but a tragedy for those who feel.
Let your smile change the world. Don’t let the world change your smile.
RMIGHTY1 is offline
post #6 of 7 (permalink) Old 05-04-2015, 04:21 PM
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Frank. Can you give some additional details abiut the jig? It looks prety interesting to me?
We, woodworkers are everywhere!!!
papasombre is offline
post #7 of 7 (permalink) Old 05-04-2015, 11:36 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Alexis, I made this with scrap wood.
The "box" was made to cradle the log all the way around. That way I did not have to drive screws or nails into the log or use wedges to hold it in place.
The "slide" was made from the same scrap wood. As it turned out it was almost too thick for me to use. Between the thickness of the wood slide and the router base, I used every inch of the router bit's length and the max depth of the router's shaft to reach my desired depth of cut into the log. I even took the router's base plate off and mounted the router to the sled for an extra 1/8" depth of cut. Working at the extreme limits like this is not the smartest thing to do.....but I got away with it this time. I will make me a new slide before using it again......a thinner set so I don't have to push the limits of safety next time.
I installed slide stops under the slide so I would not cut into my case. Using the outside edges of the slide I was able to maneuver the router back and forth to cut the log. But, when it came time for the precise, close cuts, I still held on to the router.....didn't trust myself fully just yet.
I took my time to make the jig with smooth, rounded edges. Be sure and make the slot in your sled wide enough for you to see what's happening with the cutter and to allow chip clearance. I used screws so I could take it all apart and make dimensional changes for the next project I will use it on.
I really like working with logs. Using this method to hold the logs in place makes this part of my jig safe for me to work. It's probably not the most technical system, but it works for me.
When you are designing one for yourself, just take your time and think about every way you can get hurt trying to hold down a piece of material. There are safe ways; there are quick ways; but there are few ways that are quick and safe. I trust my design.....but that doesn't mean it's the safest method out there. So use a lot of common sense when you make one.
Thanks for asking.....and post pictures of yours!!
Frank
Frankj3 is offline
Cross Cuts Differ From Rip Cuts... Jerry Bowen Tools and Woodworking 9 07-15-2013 11:27 AM
Cross dowell help drbbob Jigs and Fixtures 6 06-17-2013 03:43 AM
Jerry's latest observation on accurate cross cuts Jerry Bowen Tools and Woodworking 32 10-15-2012 10:34 PM
Making a cross or a crucifix Grumpy Old Tom Project Plans and How To 3 07-31-2012 01:21 PM
Church cross DPLRBruno Show N' Tell 8 03-20-2009 08:26 AM
