A Little Guidance Please - Router Forums
 7Likes
post #1 of 18 (permalink) Old 03-21-2015, 11:33 PM Thread Starter
Frankj3's Avatar
First Name: Frank
Default A Little Guidance Please
I made my grandson an outside toy box for his 1st birthday.
I used 5/4 treated deck boards and applied 5 coats of clear acrylic, both inside and out. There is about a 1/8" gap between boards to allow the dirt and water to drain.
Look at his name......forget that the "O" letters are not round.....my belly is but not the letters! LOL
My dilemma was with the letter "P" in his name. The material had deep embedded grains that would sometimes force my bit to push off in another direction.....in this case, into the letter.
Short of using clamped on guides, do any of you have a suggestion on combating this issue? I use a Rigid trim router for my letters and I really like it. Maybe in this type of wood I need to use a "heavier" router. That way maybe it would be harder for the grains to force the bit to wonder off line.
Any suggestions?
Thanks for the input!
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #2 of 18 (permalink) Old 03-22-2015, 12:04 AM
Any suggestions?
deeply knife score the outline and climb cut...
since it's an out door box in a month or so you'll never see what you believe to be issues..
side note...
watch your child for PT splinters... it's possible that they could go septic because of a reaction to the ACQ...
RMIGHTY1 likes this.
post #3 of 18 (permalink) Old 03-22-2015, 12:13 AM Thread Starter
Frankj3's Avatar
First Name: Frank
Thanks Stick!
Frank
Frankj3 is offline
post #4 of 18 (permalink) Old 03-22-2015, 12:36 AM
Frank; you may have problems with the finish bonding. Apparently ACQ lumber is supposed to be weathered for a year before stains an/or finishes are applied. Some kind of chemical incompatibility (?).
Nice job on the toy box...Cooper won't ever notice, unless you tell him!
DaninVan is offline
post #5 of 18 (permalink) Old 03-22-2015, 12:46 AM Thread Starter
Frankj3's Avatar
First Name: Frank
The wood is not quite a year old.....maybe 9 months or so. It's left over from replacing the deck flooring. I put down the new decking down at the start of last summer. Hopefully it will hold up.
Frank
Frankj3 is offline
post #6 of 18 (permalink) Old 03-22-2015, 12:47 AM
First Name: Ray
Hi Frank. I seem to recall Dave Rhoten demonstrating a slightly deeper cut around the outside of his letters to prevent that from happening when he did the background cut. I have no idea what episode that was in but if I find it I will share it here. Essentially he was doing with his router what stick said about a deep knife score.
Your sign sure looks nice. I love it!!!
P.S. Here it is. Listen from 1:35 to 2:10 seconds:
https://www.youtube.com/watch?v=7EQiBnUeESE
Copyright©2015 A.D. (Anno Domini, Latin for "in the year of our Lord") e.g., historical FACT!
Life is a comedy for those who think, but a tragedy for those who feel.
Let your smile change the world. Don’t let the world change your smile.
RMIGHTY1 is offline
post #7 of 18 (permalink) Old 03-22-2015, 06:39 AM Thread Starter
Frankj3's Avatar
First Name: Frank
Ray, that problem occurred when I was cutting out the letters. For once I resisted the urge to correct it.......for fear of making it worse......i.e. shorter than the other letters.
I need to trust my abilities to make larger swirls when cutting out the background, I'm making the cuts too shallow and smaller than they need to be.....which takes longer.
Thanks!
Frank
Frankj3 is offline
post #8 of 18 (permalink) Old 03-22-2015, 11:38 AM
Frank I don't see a problem and if you don't say anything, no one else will either. Nice job.
Bill
billyjim is offline
post #9 of 18 (permalink) Old 03-22-2015, 11:44 AM
Frank a heavier router will probably also mean a more powerful router which can also make it harder to control when it wants to wander around. The only thing I would suggest is that something like a DeWalt 611 which is only marginally more powerful but also has handles might be a little easier to control because of the different ergonomics.
post #10 of 18 (permalink) Old 03-22-2015, 12:40 PM
kp91's Avatar
First Name: Doug
Bill
My thoughts exactly.
The tapered carving bits make it a little easier to control.
1 John 1:9
Fredericksburg, VA
kp91 is online now
Need Cabinet Building Guidance for my Workshop Lonely Raven Starting Off 16 11-20-2012 10:53 AM
Newbie looking for guidance - Software LAMEIII CNC Routing 0 01-15-2011 04:17 PM
Guidance for making wood signs rvguy Sign Making 3 10-10-2007 08:56 AM
Need advice and guidance for routing picture frames popmoon Table-mounted Routing 26 03-11-2007 11:11 PM
Guidance on a new Router purchase Gilbear Tools and Woodworking 8 12-15-2005 12:32 PM
