2" wide letters for bar top - Router Forums
 14Likes
post #1 of 14 (permalink) Old 04-03-2015, 10:45 AM Thread Starter
First Name: Scott
Default 2" wide letters for bar top
I'm building a bar top out of 1x pine boards. I thought it would be neat to try and router some words on the bar top and had a design made up that is roughly 10 feet long and maybe 2 ft tall. The letters are about 2" wide. I'm going to route the letters and then paint them red. Then planning on using clear epoxy resin over the whole thing as a finish.
Can't decide what would be the best way to router the letters out. Either just use a V or round bit and trace the edges of the letters or to router the whole two inch wide letters out? That would be a lot of wood to remove and would be hard to keep the bottom flat.
Any advice on how you would do this and what bits you might use?
ponch37300 is offline
post #2 of 14 (permalink) Old 04-03-2015, 11:08 AM
Frankj3's Avatar
First Name: Frank
Scott, I would use either a profile bit or a 90 deg like you thought. My 1st choice would be the profile bit. I bought mine from Dave's Signs in Arizona. They keep them in stock.
I would trace the outside of the letters and paint the letters red. I would probably paint the cut out another color to highlight the letters. You could do this with the 90 deg bit as well.
Practice on a scrap board to see what you like best.
Lastly.......post pictures when you are finished. On this forum we like pictures!!!
Good luck!
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #3 of 14 (permalink) Old 04-03-2015, 01:53 PM Thread Starter
First Name: Scott
Frank, I never even thought about just doing the outline of the letters and then painting the leftover inside part another color. I like that. Will probably do the raised leftover inside of the letters red and the outlines black. Thanks for the suggestions.
Frankj3 likes this.
post #4 of 14 (permalink) Old 04-03-2015, 03:16 PM
MT Stringer's Avatar
I am 100% positive I would mess up the project if I tried to freehand the sign with a router. That's just me. Sometimes the router has a mind of it's own!
I did manage to use a templeate to make a couple of signs. Here is one cut in maple, sprayed with flat black paint, sanded, then sprayed with a clear finish. It turned out nice.
Good luck.
Name:	2014-10-30 15.47.40.jpg
Name:	2014-10-30 19.07.00.jpg
Name:	2014-10-30 20.07.11.jpg
Name:	2014-11-22 12.21.12.jpg
MT Stringer is offline
post #5 of 14 (permalink) Old 04-03-2015, 05:10 PM
RainMan 2.0's Avatar
Mike I'd say by that smile that you certainly got your grandkids approval lol
MT Stringer and Frankj3 like this.
Ok ,I never insulate
RainMan 2.0 is offline
post #6 of 14 (permalink) Old 04-03-2015, 06:07 PM
Frankj3's Avatar
First Name: Frank
Here's how I made the letters on my grandson's toy box.
Outset letters and the background cleaned out and painted.
MT Stringer and Nicknurse like this.
Frank
Frankj3 is offline
post #7 of 14 (permalink) Old 04-03-2015, 07:03 PM
old55's Avatar
First Name: Ross
Caiden and Cooper look quite impressed.
Frankj3 likes this.
Ross,
old55 is offline
post #8 of 14 (permalink) Old 04-03-2015, 10:13 PM
Frankj3's Avatar
First Name: Frank
Mike, is Maple easy to cut? I've never used it before.
Frank
Frankj3 is offline
post #9 of 14 (permalink) Old 04-03-2015, 10:52 PM
I wasn't cutting deep and the bit was fairly small, so I didn't have any problem with it.
Frankj3 likes this.
post #10 of 14 (permalink) Old 04-04-2015, 01:59 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
These pdf's show how I rout signs, I hope they are of some help.
File Type: pdf Routing a sign freehand by Harrysin.pdf (932.0 KB, 71 views)
RMIGHTY1, BenAtar and Nicknurse like this.
Harry
harrysin is offline
Table top display cse. derek willis Show N' Tell 16 04-13-2014 06:31 AM
Router table top? Rick in Pittsburgh Table-mounted Routing 11 09-26-2010 09:24 PM
How to best attach router table top to cabinet? xvimbi Table-mounted Routing 3 05-28-2010 07:30 AM
shallow but wide letters gusigns Router Bits - Types and Usage 2 02-01-2010 04:20 PM
Office cubicle table top for router top Noob Table-mounted Routing 12 05-23-2009 07:35 AM
