Templates for sign layout without a laser - Router Forums
 33Likes
  • 13 Post By Gaffboat
  • 2 Post By Stick486
  • 1 Post By hawkeye10
  • 3 Post By Gaffboat
  • 2 Post By hawkeye10
  • 8 Post By Gaffboat
  • 1 Post By Matador58
  • 2 Post By Frankj3
  • 1 Post By rwl7532
post #1 of 10 (permalink) Old 01-13-2016, 01:47 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Templates for sign layout without a laser
Templates are almost a necessity anytime you will be making multiples of a sign design. With the popularity of "Man Cave" signs I decided to experiment with a layout template. First I cut one on the scroll saw as sort of a test of the concept and it worked pretty well. Then I thought how much better it would be if it were laser cut and I could make more than one. I designed it with letters that are quick and easy to carve and are purposely crude so any wobbles will still look okay.
I found a company online that laser cuts various materials to your specifications in a variety of materials sized 7 x 7", 15" x 15", or 15" x 31". For my test I ordered the template cut out of double-thick corrugated cardboard in the 15" x 15" size and was able to get 5 templates on the sheet. It would be easy to set-up multiple designs on one sheet.
I received my order within 7 days and the 15" x 15" cardboard sheet came with removable white protective paper on both sides to keep the all the pieces in place. You can see the how the pieces arrived and then with the waste removed. I separated the individual templates with a utility knife. The template is used like a stencil and sprayed with ink or paint to transfer the pattern. After that it is just a matter or routing out all the black area.
You may find a template like this helpful if you have designs that are used frequently. Here's the source: Ponoko.com
Name:	1 Template unpacked.png
Name:	2 Pieces knocked out.png
Name:	3 Templates separated.png
Name:	4 Pattern Transferred.png
Name:	5 Routed.png
Name:	6 Man Cave Sign.png
Gaffboat is online now
post #2 of 10 (permalink) Old 01-13-2016, 02:15 PM
dude..
you are good...
billyjim and BobbyLee like this.
post #3 of 10 (permalink) Old 01-13-2016, 05:59 PM
hawkeye10's Avatar
First Name: Don
Oliver you have me fired up. Where can I learn about sign making?
BobbyLee likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 10 (permalink) Old 01-13-2016, 06:09 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Here's the best source with over 150 How-To videos on YouTube: OldDave100. A word of warning — sign making is addictive. Some of us may soon need a 10-step program.
Frankj3, honesttjohn and BobbyLee like this.
post #5 of 10 (permalink) Old 01-13-2016, 07:08 PM
hawkeye10's Avatar
First Name: Don
Thanks Oliver I am sure your right. It's all a money pit but what the heck.
Frankj3 and BobbyLee like this.
post #6 of 10 (permalink) Old 01-13-2016, 08:53 PM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Actually sign making is relatively inexpensive. Other than the router, you can do just about everything with four basic bits. A lot of signs are being made using cedar fence boards so even the stock is cheap. Here are the bits:
(1) The Profile Bit is has 15º sides that taper to 60º at the tip. Used to carve images and around the edges of the letter for outset text. Outset meaning the letter remains as wood with the background carved away from it.
(2) The Whiteside SC50 bit. Has a very fine point and use for very small detail. Can't be used much deeper than 3/32" because the tip is so sharply pointed it can break with too much lateral stress.
(3) The 60º bit is used for inset letters (the letter is carved out of the wood) and for larger image carving
(4) The 90º bit is used create a knobby pattern as you carve away the backgrounds around text and the inside of images. I have also used a spiral bit when I want a smooth flat background.
Name:	Sign Carving-Bits.png
post #7 of 10 (permalink) Old 01-14-2016, 04:16 AM
First Name: Graham
Hi Gaffboat,
Very nice signs well done.
Graham.
Matador58 is offline
post #8 of 10 (permalink) Old 01-14-2016, 11:14 AM
rwl7532's Avatar
First Name: Ralph
What was your cost?
  • Accident free since 10/27/12 at 3:58 pm.
  • Cursing free since 10/27/12 at 3:59 pm.
  • ...it happened in Everett, WA USA
rwl7532 is offline
post #9 of 10 (permalink) Old 01-14-2016, 01:55 PM
Frankj3's Avatar
First Name: Frank
A most excellent post and explanation Oliver.
I'm not so sure a 10 step procedure will work for me......it may take a LOT more than that!! LOL
Gaffboat and BobbyLee like this.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #10 of 10 (permalink) Old 01-14-2016, 03:47 PM
rwl7532's Avatar
First Name: Ralph
"purposely crude"
It is after all, a cave!
rwl7532 is offline
Acrylic router templates pagoda69 General Routing 5 11-19-2012 07:12 AM
For Sale: Misc Router Inlay Templates dovetail_65 Woodworking Classifieds 3 02-21-2011 11:55 AM
Templates - table v. plunge routers charleyb Guide Bushings and Templates 5 06-03-2009 07:35 PM
Laser Cut Router Templates - 1/4" Acrylic fordcraftsmanstudios Jigs and Fixtures 16 02-26-2009 08:02 PM
