Marsh spray ink? - Router Forums
 7Likes
post #1 of 12 (permalink) Old 01-17-2016, 06:03 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Marsh spray ink?
I have not heard of this before. What are the advantages of using ink on signs?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 12 (permalink) Old 01-17-2016, 06:33 PM
waterproof, very permanent and expensive...
post #3 of 12 (permalink) Old 01-17-2016, 08:10 PM
Don,is this to make the signs or after the signs are made?
Herb Stoops is online now
post #4 of 12 (permalink) Old 01-17-2016, 08:18 PM
it's original use was stencil ink...
Herb Stoops likes this.
post #5 of 12 (permalink) Old 01-17-2016, 09:01 PM
kp91's Avatar
First Name: Doug
http://www.amazon.com/MARSH-Stencil-.../dp/B00DLD7JO8
It's not too expensive, the Dave Rhoten sign making videos use ink instead of paint for laying out their signs because it dries quick and doesn't soak too far into the wood
UlrichJ and Herb Stoops like this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #6 of 12 (permalink) Old 01-17-2016, 10:42 PM
Gaffboat's Avatar
First Name: Oliver
Both. You can use it to lay out the sign and then color the carved area after routing. The ink dries a little faster than paint but I find myself using them interchangeably. The ink tends to be a little thinner than the paint and has less chance of laying on too thick a coat. The downside is the expense.
Gaffboat is offline
post #7 of 12 (permalink) Old 01-18-2016, 08:07 AM
Garyk's Avatar
First Name: Gary
Given that ink is not as thick as paint would it not seep beyond the intended boundaries ?
Garyk is offline
post #8 of 12 (permalink) Old 01-18-2016, 08:53 AM
Frankj3's Avatar
First Name: Frank
The ink does not run like most paints. Therefore it doesn't seep into most woods like paint.
The Rhotens made the change to a paint by Rust Oleum called 2X Black Primer.....for cost savings. They still use the Marsh Ink occasionally.
I have never used the Marsh ink.....only black spray paint and the 2X black primer. I love the black primer. I akso use the 2X Glossy Clear acrylic for a finish.
hawkeye10 likes this.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
post #9 of 12 (permalink) Old 01-18-2016, 09:08 AM
wicking??
depends on the wood...
open cell could become an endeavor...
post #10 of 12 (permalink) Old 01-18-2016, 09:14 AM
I akso use the 2X Glossy Clear acrylic for a finish.[/QUOTE]
Gotta love that Glossy Clear - that's what I use when there's too much detail to brush on Poly or Spar. The smell sucks til it dries, but it's som good stuff.
HJ
Frankj3 likes this.
honesttjohn is offline
Over spray? hawkeye10 The Finishing Touch 27 09-11-2015 11:40 PM
Spray Finishing Booth berry Tools and Woodworking 7 06-13-2014 02:14 PM
spray can stencil ink wulliepie1 Lobby 4 10-22-2012 10:50 AM
Looking at spray guns fasttruck860 Tools and Woodworking 17 02-19-2011 10:59 PM
