Routing small signs - Router Forums
 17Likes
  • 8 Post By Gaffboat
  • 1 Post By kp91
  • 3 Post By Gaffboat
  • 1 Post By hawkeye10
  • 2 Post By Gaffboat
  • 1 Post By Roy Drake
  • 1 Post By tomp913
post #1 of 8 (permalink) Old 02-29-2016, 09:46 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
Default Routing small signs
I thought it would be nice to make a title sign for my Woodlot Incident project so I made this one out of some 1/4" poplar. It turned out well enough that I think there is some potential for making more signs like this for desk nameplates or such.
The length is 6" and the letters are 1/2" tall. Of course, the concept of pricing a sign by the square foot doesn't work too well in this case since it is only about 1/16th of a square foot.
berry, chessnut2, TenGees and 5 others like this.
Gaffboat is offline
post #2 of 8 (permalink) Old 02-29-2016, 10:07 AM
kp91's Avatar
First Name: Doug
Very nice Oliver! What bit did you use?
BobbyLee likes this.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 8 (permalink) Old 02-29-2016, 10:13 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
I used the Whiteside SC50 fine detail bit for the letters and tight background areas then used the 90 bit to clean out the rest of the background. The weathered edges of the sign were cut with a utility knife.
Frankj3, hawkeye10 and BobbyLee like this.
Gaffboat is offline
post #4 of 8 (permalink) Old 02-29-2016, 10:57 AM
hawkeye10's Avatar
First Name: Don
Another great sign Oliver. Did you surround the work piece with 1/4" material to keep the router from tipping?
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 8 (permalink) Old 02-29-2016, 11:13 AM Thread Starter
Gaffboat's Avatar
First Name: Oliver
I started to, Don, but there was a very slight difference in thickness between the pieces which caused a step I could feel as I moved the router base, so I abandoned the extra material. I was also resting my work on a non-skid mat which, combined with the thin material, caused it to sort of tilt back and forth. To alleviate that I attached the sign blank to large thick piece of mdf with double-sided tape which gave me a very solid surface and made it easy to keep the router from tipping.
Frankj3 and BobbyLee like this.
Gaffboat is offline
post #6 of 8 (permalink) Old 02-29-2016, 11:36 AM
BobbyLee's Avatar
First Name: BobbyLee
Very nicely done Oliver. Thanks for sharing. I still need to get a sc50 bit and a good 90 degree v groove. Also want to get another profile bit to have on hand for those times when I send in my other one for sharpening I'm not left sitting here without a bit. Plus sharing everything with my 13 year old nephew puts double duty on all my bits.
A piece of wood a day; Helps keep the ill troubles of life away..
BobbyLee is offline
post #7 of 8 (permalink) Old 03-01-2016, 08:21 AM
First Name: Roy
Very nice. Now, Oliver, concerning your mind...
Roy Drake is offline
post #8 of 8 (permalink) Old 03-01-2016, 09:21 AM
How about the idea of adding four adjustable "feet" to the corners of the router baseplate - the height of the feet could be adjusted based on the material thickness - and this would give support to the router and prevent tipping when routing small pieces like this.
BTW loved your Woodland Incident project, both innovative and outstanding workmanship.
tomp913 is online now
Routing & Painting Name Signs JoeM Sign Making 17 10-07-2014 10:30 AM
Routing Unique Signs To Sell jrandolph59 New Member Introductions 6 04-01-2014 12:23 PM
routing small round tables border spartafoto Table-mounted Routing 4 11-21-2011 08:31 AM
What kind of wood for routing signs BC Wood Worx Sign Making 22 10-06-2011 12:09 PM
Looking for info on small cnc routing systems dtjoint CNC Routing 1 10-11-2010 12:24 AM
