Makita modifcations for sign making. - Router Forums
 5Likes
  • 3 Post By hawkeye10
  • 1 Post By tvman44
  • 1 Post By Frankj3
post #1 of 4 (permalink) Old 03-09-2016, 02:24 PM Thread Starter
hawkeye10's Avatar
First Name: Don
Default Makita modifcations for sign making.
Here is what I did to improve my router for making signs. The cost was very little. I already had everything I needed. The router motor doesn't go all the way down so I didn't have to worry about the motor hitting any thing. I used 1/4 X 20 all thread to mount the handles. Using a 13/64 drill bit I drilled a hole on each side of the router base and tapped them with a 1/4 X 20 tap. Be fore cutting the all thread to length I put a nut on one end then clamped it up so I could bend it. Leaving the all thread long made it easy to bend. I then cut them to length. I made my handles out of some cork stoppers I had left over from making piggy banks for Christmas presents. There is a lot of ways to make your handles for free just think about it. I glued the handles on with Gorilla glue and let it set over night. This mourning I put a nut on the all thread then put some lock tight on the threads and mounted the handles. Be sure not to over tighten the nut against the cast housing it might crack it. There is nothing about these handles that need to be super strong. There isn't much strain on them. I hope this might help someone with some ideas on modifying their router.
rcp612, RÖENTGEEP and BobbyLee like this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #2 of 4 (permalink) Old 03-12-2016, 06:40 AM
BobbyLee's Avatar
First Name: BobbyLee
Works for me Don. Happy Carving Brother...
A piece of wood a day; Helps keep the ill troubles of life away..
BobbyLee is offline
post #3 of 4 (permalink) Old 03-12-2016, 08:14 AM
tvman44's Avatar
First Name: Bob
Good thinking!
BobbyLee likes this.
Papa Bob
Using a couple of old Craftsman routers & a Bosch 1617EVSPK & a Dewalt DWP611PK Routers in SW Louisiana.
tvman44 is offline
post #4 of 4 (permalink) Old 03-12-2016, 09:57 AM
Frankj3's Avatar
First Name: Frank
Mods done right.....for the right reason....with items on hand.....just make good sense to me!!!
Great mod Don!!! I'm gonna look into maybe doing that to my Ridgid palm router.
Frank
I may not know what I'm doing, but I am having fun doing it wrong!!
Happy Day Veterans!!
Frankj3 is offline
Rockler Fluting Jig and Makita RT0700c Doicholiday Tools and Woodworking 4 11-13-2015 01:19 PM
Can i use a makita router with a makita template guide with a porter cable jig? oshinobi Jigs and Fixtures 2 06-17-2009 12:24 AM
Makita Router Opinions Please Birch General Routing 30 02-20-2009 09:47 PM
Makita 3612C TWheels General Routing 8 11-23-2008 06:58 PM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 02:23 AM
