New Piece In Progress - Router Forums
 33Likes
post #1 of 25 (permalink) Old 06-25-2016, 02:49 AM Thread Starter
BobbyLee's Avatar
First Name: BobbyLee
Default New Piece In Progress
New piece I just cut and am currently working on. Either going to add; Ride To Live, Live To Ride separately under each of the wings across the bottom. Or BobbyLee & Nancy under the wings. Coin flip at the moment. Can hardly wait to paint it after a light sand first and see it with paint and clear coat on it.
Name:	Aercan Harey davidson Eagle.jpg
A piece of wood a day; Helps keep the ill troubles of life away..
BobbyLee is offline
post #2 of 25 (permalink) Old 06-25-2016, 02:53 AM
very well done Bobby..
BobbyLee likes this.
post #3 of 25 (permalink) Old 06-25-2016, 03:02 AM Thread Starter
BobbyLee's Avatar
Thanks Stick. Really needed my magnifier for cutting those stars in with my SC-50 line carving bit. Wings were done with Profile bit.
BobbyLee is offline
post #4 of 25 (permalink) Old 06-25-2016, 05:52 AM
hawkeye10's Avatar
First Name: Don
Bobby you amaze me. I just tried to make a sign that wasn't near as complicated as yours and it's trash. How are you painting yours? It looks like an air brush would be handy.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #5 of 25 (permalink) Old 06-25-2016, 06:03 AM
First Name: Ken
That looks great...and difficult! Nice work!
kklowell is offline
post #6 of 25 (permalink) Old 06-25-2016, 07:38 AM
Gaffboat's Avatar
First Name: Oliver
This may be your best yet, Bobby Lee. Excellent job.
Gaffboat is online now
post #7 of 25 (permalink) Old 06-25-2016, 10:01 AM
MEBCWD's Avatar
Beautiful pattern Bobby Lee. Really nice hand cutting job to get all that detail.
MEBCWD is offline
post #8 of 25 (permalink) Old 06-25-2016, 01:00 PM Thread Starter
BobbyLee's Avatar
Don as of now I am using a combination of Acrylics and Paint Pens. On this piece I am probably going to use my fine tip brush and acrylics to paint all the stars and then paint pens for the red, white & blue areas.
I am wanting to get an air brush set up probably in the next few months. But as for now, will work with what I have on hand.
I purchased my paint pens from walmart; $1.97 a piece. Most are medium tip. Plan to get more fine tips when ever the restock. They work great if used properly. Trick is not to depress the tip to long to the point the paint puddles out. Hope this helps out.
BobbyLee is offline
post #9 of 25 (permalink) Old 06-25-2016, 01:11 PM Thread Starter
BobbyLee's Avatar
Thanks Ken. Most tedious part was taking my time on the stars. Dropping the tip of my SC-50 bit slightly into each tip of the stars. Rest was pretty much easy going.
Some pieces I use spray adhesive and carve straight through my paper layout. Other more detailed pieces I use carbon paper and trace my layout, so I don't risk the paper tearing or pealing off on the detailed areas.
BobbyLee is offline
post #10 of 25 (permalink) Old 06-25-2016, 01:13 PM
vchiarelli's Avatar
First Name: Vince
Great sign Bobby - my suggestion: go with BobbyLee & Nancy. "Ride to Live...... " is too common
vchiarelli is offline
Details and pix of spline jig DesertRatTom Project Plans and How To 9 06-19-2016 07:48 AM
Table saw long piece cutting jig Dejure Jigs and Fixtures 2 06-13-2016 11:54 AM
Latest Piece In Progress BobbyLee Sign Making 14 04-07-2016 07:56 PM
Make a template to create a filler piece? Ric Naff Jigs and Fixtures 3 01-12-2006 07:56 PM
One piece stile & rail bit tsringcutter Table-mounted Routing 3 01-10-2006 08:44 PM
