R way tack sign - Router Forums
 14Likes
  • 9 Post By BobbyLee
  • 1 Post By hawkeye10
  • 1 Post By Shop guy
  • 1 Post By RainMan 2.0
  • 1 Post By Stick486
  • 1 Post By MEBCWD
post #1 of 6 (permalink) Old 07-23-2016, 04:53 AM Thread Starter
BobbyLee's Avatar
First Name: BobbyLee
Default R way tack sign
New one I'm just finishing up for a customer.
2' x 2' Panel Board. Cut with a 1/8th & 1/16 straight bit. Ready for the clear. Sprayed with clear lacquer before applying primer to prevent any bleeding.
With finish on it. Still drying and will probably do one more coat.. Working through the night as usual. Seems like I constantly Ride That Red Eye...
Name:	R Way Tack With Finish.jpg
BrianS, Gaffboat, marecat3 and 6 others like this.
A piece of wood a day; Helps keep the ill troubles of life away..
BobbyLee is offline
post #2 of 6 (permalink) Old 07-23-2016, 08:31 AM
hawkeye10's Avatar
First Name: Don
Your a pro Bobby.
BobbyLee likes this.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #3 of 6 (permalink) Old 07-23-2016, 08:53 AM
First Name: Richard
Bobby Lee does it again. Nice
Shop guy is offline
post #4 of 6 (permalink) Old 07-23-2016, 11:06 AM
RainMan 2.0's Avatar
Wow , is that ever nice !
Ok ,I never insulate
RainMan 2.0 is offline
post #5 of 6 (permalink) Old 07-23-2016, 12:02 PM
and again....
post #6 of 6 (permalink) Old 07-28-2016, 10:39 AM
MEBCWD's Avatar
Bobby Lee,
Turned out real nice. The customer should be very happy.
MEBCWD is offline
Dirty Little Secrets with Sign Making... newmexico Sign Making 45 06-18-2016 02:59 PM
Sign making Idea's? RouteringRookie Starting Off 9 04-28-2016 01:28 PM
New sign start to finish L Town Graphics Sign Making 16 02-03-2014 06:52 AM
Sign material & Sign templates Gunpowder Sign Making 1 09-18-2008 06:30 PM
