Post Didn't Show Up - Router Forums
post #1 of 14 (permalink) Old 03-05-2015, 06:02 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Default Post Didn't Show Up
Morning y'all,
I typed a rather lengthy post complete with pictures last night and pushed the submit button. It never showed up on the forum. Should I try again, or will it show later?
DonkeyHody is offline
post #2 of 14 (permalink) Old 03-05-2015, 07:47 AM
No, I'm pretty sure it's gone. I was having problems with failing posts for a while and I got into the habit of copying so I could paste them to a retry if they failed. I've seen someone (Stick I think) suggest a few keystrokes that can recover it but I don't remember them.
post #3 of 14 (permalink) Old 03-05-2015, 07:55 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
Thanks. I think I'll give Stick a little while to get up and get his morning coffee. Maybe he'll see my post and tell me the secret. I really don't know if I can remember everything I said, but it was profound I'm sure! (not)
post #4 of 14 (permalink) Old 03-05-2015, 10:06 AM
Ctrl + Z sometimes...
I've been losing a post every so often too and it's a hit or miss recovery...
but the log in screen often is getting a bit old...
Stick486 is offline
post #5 of 14 (permalink) Old 03-05-2015, 10:11 AM Thread Starter
DonkeyHody's Avatar
First Name: Andy
I've brrn losing a post every so often and it's a hit or miss recovery...
Not this time, but THANKS!
post #6 of 14 (permalink) Old 03-05-2015, 10:41 AM
Gaffboat's Avatar
First Name: Oliver
If I have a long post I type it in a text editor first and then cut and paste it into the forum post. That way if it fails I still have a copy and it also gives me a chance to do better editing so I don't look like a complete idiot (still an idiot, but only partially).
Gaffboat is online now
post #7 of 14 (permalink) Old 03-05-2015, 10:42 AM
Ctrl+Z needs to be immediately done after loosing a post...
keep in mind it's a hit or miss thing...
Stick486 is offline
post #8 of 14 (permalink) Old 03-05-2015, 11:08 AM
Morning y'all,
Plan ''B''
to left of of the URL address bar is an arrow pointing to the left...
right click on that and select a message window you were at...
or left click on the arrow once/twice or how ever many times you need to to back up to your reply window...
again, this is a hit or miss deal...
if you haven't closed your browser since the failed post you may still be able to "back up"...
then again if your "history" isn't self cleaning or you aren't using private browsing you still have a "shot" at recovery...
Stick486 is offline
post #9 of 14 (permalink) Old 03-05-2015, 01:09 PM
First Name: Katie
I seem to be having this problem all the time, to the extent that I have not been able to post a new message for a day or so. When I hit the submit button, it looks like it is going to post my message, but then it just hangs there. I've tried two different browsers and they both do the same thing. I'm wondering if this is a site problem. I seem to be able to reply to others' posts, but not start new ones.
I also shut down my computer with a cold start and that did not fix the problem. It did seem to help one other time when I did this.
Goblu is offline
post #10 of 14 (permalink) Old 03-05-2015, 01:11 PM
RainMan 2.0's Avatar
I've had no issues
Ok ,I never insulate
RainMan 2.0 is offline
Global Community Rules and Guidelines Mark Site Help and Suggestions 0 03-15-2009 10:39 PM
You may post attachments
