Formula Help (radius) - Router Forums
post #1 of 3 (permalink) Old 05-15-2008, 12:49 PM Thread Starter
Default Formula Help (radius)
To figure the compound curve when designing cathedral doors
([(10/4)^2/(4-2.25)/2]+(4-2.25)/2)/2
10 dist between stiles
4-2.25 is max rail width - min rail width
the answer is 1.3
I believe I am calculating this wrong. Can you help?
Thanks in advance
thomb is offline
post #2 of 3 (permalink) Old 05-15-2008, 01:31 PM
Hi Thomb
I'm not to sure why you are playing with the numbers,,, it takes two templates to make a cathedral door... and all the math is done for you with the premade templates..
They come in many sizes, to make a 4" wide door to a 24" wide door...
Many woodworkers supply companys sell them here's just two of them..
http://www.sommerfeldtools.com/prodinfo.asp?number=TMP3
http://www.sommerfeldtools.com/prodi...p?number=CLTMP
http://www.ptreeusa.com/routerAcc.htm#20262
Raised Panel Door Calculato
http://www.1888softwaredownloads.com...oors-4336.html
20mb file, Shareware
http://www.cheyennesales.com/download/rpdcalc.htm
post #3 of 3 (permalink) Old 05-15-2008, 02:24 PM Thread Starter
what was i thinking.
thomb is offline
Determining a radius cut RoyBullets Jigs and Fixtures 7 06-23-2008 08:10 AM
Corner Radius bobj3 Tools and Woodworking 25 09-29-2007 05:51 PM
Working with radius MiamiSnookII Starting Off 5 01-07-2006 10:20 AM
3/4" Radius roundover bit with 1/4" shank chrisogrady Router Bits - Types and Usage 8 04-01-2005 08:08 PM
Router Table Plate Radius DONALD Table-mounted Routing 2 02-27-2005 09:26 AM
You may post attachments
