Metal dust collection system - Router Forums
 14Likes
post #1 of 27 (permalink) Old 01-31-2016, 07:14 PM Thread Starter
Oakwerks's Avatar
First Name: Kurt
Default Metal dust collection system
I've read many articles on dust collection duct material....
Most show/recommend PVC, but I've never found anything recommending galvanized stove pipe....
I went ahead and piped mine using it, anyway....
The fittings fit standard 4 inch flex hose and blast gates with no modifications...
Since these pics were taken, I have swapped out the dust bag for a Winn NANO pleated filter.... This improved air flow dramatically.
Oakwerks is offline
post #2 of 27 (permalink) Old 01-31-2016, 07:18 PM
First Name: Keith
Kurt, I wonder if it would have anything to do with way the pipes are made...the seam running end to end and all. Could be some potential leakage there.
You could likely improve the system even further if you duct tape the seams and the joints, that is assuming you haven't done so already. Just a thought.
DaninVan likes this.
cocobolo1 is offline
post #3 of 27 (permalink) Old 01-31-2016, 07:23 PM Thread Starter
Oakwerks's Avatar
First Name: Kurt
I have... Many of the joints leaked.... First time in my life I used duct tape for the intended purpose....
Oakwerks is offline
post #4 of 27 (permalink) Old 01-31-2016, 08:18 PM
How large of dust collector do you have? Motor and fan diam.? What is the diam. of duct 5",6"8"? is it single wall, or double wall?
Herb Stoops is offline
post #5 of 27 (permalink) Old 01-31-2016, 08:19 PM
this where foil tape comes into play...
metal is re-workable with little to no waste...
http://www.routerforums.com/featured...on-system.html
http://www.routerforums.com/introduc...df-boards.html
Stick486 is offline
post #6 of 27 (permalink) Old 01-31-2016, 09:17 PM
First Name: Clay
Looks great. I think I would use foil tape for the joints. Let us know how it works out. AND there is no reason to try to ground a system.
fire65 is offline
post #7 of 27 (permalink) Old 01-31-2016, 09:31 PM
Dejure's Avatar
First Name: Kelly
Good tip. I'd just bump it up to the foil tape. It doesn't break down over time like so called duct tape does.
The reason I have what you want is, I never lent it out before.
Scraps are a myth.
Dejure is offline
post #8 of 27 (permalink) Old 01-31-2016, 09:38 PM
please ramp up the health and safety and DO ground...
Stick486 is offline
post #9 of 27 (permalink) Old 02-01-2016, 01:01 AM
First Name: Clay
I say again, NO REASON TO GROUND.
fire65 is offline
post #10 of 27 (permalink) Old 02-01-2016, 01:07 AM
carry on...
fire65 and LazurusLong like this.
Stick486 is offline
Tips for Installing a Dust Collection System Router Forums Featured Topics 121 02-24-2017 12:20 PM
Miscellaneous Dust Collection Stuff MT Stringer Show N' Tell 9 12-01-2014 12:54 PM
Update On Dust Right System Jerry Bowen Tools and Woodworking 2 07-18-2012 01:15 PM
Reconsidering Router Table Dust Collection JohnnyB60 Table-mounted Routing 20 05-03-2012 01:01 AM
Dust collection system for Router Table yhadar Lobby 2 12-31-2004 02:37 PM
You may post attachments
