Reverse speed possible? - Router Forums
post #1 of 7 (permalink) Old 08-07-2010, 03:53 PM Thread Starter
Country: Slovenia
First Name: Felix
Thumbs up Reverse speed possible?
Hello all!
I am having some troubles because I want to connect multiple boards using special router bit to do table top (only one face needs to be flat). Because they aren't equal wide (and I don't have thicknesser machine) I modified bit by placing each of its parts together in contra order. Well, that's why I need reverse spinning of my Makita RP2301. Is there any mistrial way to do this?
Thank you for answers!
paskvale is offline
post #2 of 7 (permalink) Old 08-07-2010, 10:09 PM
MikeMa's Avatar
I know some models of shapers can be reversed, but I have never heard of a router being reversed. In theory (strictly speaking in theory) it may be possible to rewire a router to run in reverse direction, however the bearings and/or bushings may not be made to go in the reverse direction. Plus if it is a soft start or variable speed that would complicate it even more. Not to mention you are likely to burn out the motor doing so.
I will also note, I would be real hesitant to use a modified router bit which it sounds like you are attempting to use. This bit maybe spinning anywhere from 25k to 30k RPMs. If it comes flying apart you risking serious injury.
My advice to you, find someone who has a planer and see if they would be willing to properly size the boards for you. The use a ready-made bit to accomplish what you are setting out to do.
MikeMa is offline
post #3 of 7 (permalink) Old 08-08-2010, 02:24 AM
Felix, the only machines that spin bits in reverse direction are expensive production machines. I would not attempt to reverse a router. You are much better off putting a sign in your woodworking supply and finding a new friend who has a planer.
post #4 of 7 (permalink) Old 08-08-2010, 07:50 AM
Jack Wilson's Avatar
First Name: Jack
Mike & Mike, keep in mind that Felix is from Slovenia, I am not sure how it works over there, but it may not be as simple as posting a sign in the local lumber yard.
Felix, how did you come by your lumber? Would it be possible to have it machined somewhat at the place of purchase? Have them do what you are not tooled up for?
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #5 of 7 (permalink) Old 08-09-2010, 01:36 AM Thread Starter
Country: Slovenia
First Name: Felix
I see...no simple solution then. I will have to borrow a thicknesser machine somewhere. Thank's for your answers!
paskvale is offline
post #6 of 7 (permalink) Old 08-09-2010, 04:24 PM
RJM60's Avatar
First Name: Robert
Originally Posted by paskvale View Post
Hello all!
Maybe you puit the bit back together wrong. Couldn't you just flip the cutters so they cut when the bit spins the correct way.
RJM60 is offline
post #7 of 7 (permalink) Old 08-16-2010, 01:02 AM Thread Starter
Country: Slovenia
First Name: Felix
No, definetly not!
paskvale is offline
Variable Speed vs. Fixed Speed Phillip K General Routing 26 10-23-2013 10:38 AM
Bypassing Craftsman variable speed control emptyjay General Routing 13 02-14-2011 04:10 PM
Router Bit Sizes And Variable Speed Settings mack. Router Bits - Types and Usage 4 02-18-2010 11:33 PM
What to choose? Need a knew Lrg. Router and plate set-up toadsage Table-mounted Routing 5 11-10-2009 10:24 PM
adding a speed controller to a single speed router Sawatzky Table-mounted Routing 5 01-24-2009 08:49 AM
