Using Power Tools with Medication - Page 3 - Router Forums
post #21 of 31 (permalink) Old 02-10-2013, 03:02 PM
Phil P's Avatar
First Name: Phil
Originally Posted by JanP View Post
Well I took off my thumb nail and ended up on the floor and sprained my wrist and because I have problems getting up, I stayed there until my wife found me.
Hi Ian
You may be making a case for lateral thinking. A hand conventional hand held router, even a D-handle one requires a two hand hold and a stable stance. Using 1/2in plunge routers (sorry gents, but in the UK plunge is about all you'll get in 1/2in), with all the extra weight and power (and torque reaction that comes from that power) adds to the potential problems. There are two approaches I can think of - firstly a back-handle router and secondly an overhead (pin) router. Of the former I can only think of two models still on the market, the Festool OF1010 (which replaced the earlier OF900 and OF1000 models) and the Mafell LO50e which is is possible to us one handed and which aren't overly heavy:
Above: Festool OF1010 8mm plunge router
Below: Mafell LO50e 8mm plunge router
If you think they look similar it's because they are both made by Festool.....
In use, except for making the plunge, these routers are easily controlled single handed if needs be:
At 1000 and 900 watts respectively (I think) they have enough power to handle a lot of routing tasks without getting bogged down and they are considerably less "tippy" in use that laminate-trimmers or those "palm routers" such as the DW611 derived from them. Elu used to make an even lighter model, the 600 watt MOF67, but as they haven't been made since the late 1980s or early 1990s I think you'd struggle to find one.
Of course it is possible to get a heavier back-handle router, the one known example being the Festool OF1400:
but that comes with a lot greater power and a lot more weight to manage.
The other possibility might be to consider some form of overhead pin router, such as the ShopSmith attachment
or one of the many home-made add-ons for radial arm saws and drill presses seen around the web. With an overhead router you don'y have to hold the router's weight, only the weight of the material - and not even that iy your support table is big enough. I can confirm that to use a pin router (industrial in my case) for a day is somewhat less tiring than using a hand-held 2000 watt plunge router for the day, assuming the same rate of working (which in reality doesn't happen - you tend to work much faster on a pin router). Of course the other way is to attach your router beneath a table.....
Regards
Phil
Phil P is offline
post #22 of 31 (permalink) Old 02-12-2013, 10:40 PM
First Name: Rob
I am new here and have mostly been lurking, but I am also disabled (or so the US Gov't says, and they send me a check for it). I was injured at work in 2008 (Proctor and Gamble, Folgers Plant), and require back, neck, wrist, and elbow surgeries, and still do, haven't had the guts to do any of them as of yet. Now that I have my SSDI approved I will slowly get them done.
I am also on strong pain meds (Oxycodone 30mg, Hydrocodone 10/650, and at night I take a Soma and a Xanax to help me sleep). I have slowly built a tolerance to these meds over the last few years and am at the max dose of each. I dread one day having to go through the withdrawals of these strong opiates when I am finally fixed, but sometimes I could not even get out of bed if it were not for these meds!
I recently found woodworking (much to the chagrin of my girlfriend) and it has really piqued my interest. It is so very therapeutic to me, and I refuse to give it up due to being on medication. The pain meds do not have a sedating feeling to me, but the opposite, they give me incredible energy, and help me to focus even more on safety. I did have a near miss yesterday on the router table, but I am new to it, and it had nothing to do with my meds.
I look forward to learning much about this hobby and being the best I can at it. I am also in my 2nd semester of College (Occupational Therapy Major), because I do not want to be on SSDI for the rest of my life! Although woodworking is cutting into my study time, I am still doing great and cannot wait to get back into the work force. I am just glad to have found this very satisfying hobby, and forums like this to help people like me.
YaBoyRob is offline
post #23 of 31 (permalink) Old 02-13-2013, 12:59 AM
Welcome to the forum, Rob.
As you have discovered, routing is not a hobby to be taken lightly even for us in the lucky position not to be on medication. [but it does not take much to change that situation].
Sydney, Australia
jw2170 is offline
post #24 of 31 (permalink) Old 02-13-2013, 07:33 AM
smokey1945's Avatar
First Name: Smokey
We are glad to have you Rob! There is a lot of know how here and they don't mind helping a guy out.
Smokey
The ShadeTreeWW
smokey1945 is offline
post #25 of 31 (permalink) Old 04-01-2013, 08:45 AM
Country: Italy
First Name: VITO CARRIERO
Salve. la tua macchina mi piace molto!!!
Ciao Vito
VITO1943 is offline
post #26 of 31 (permalink) Old 04-13-2014, 09:47 PM
First Name: Katie
Default Some regular meds are tricky
There are some meds that can cause a person to have problems that could affect them in doing woodworking but I'm not talking about painkillers and the like. I was taking zetia for high cholesterol and it caused extreme disorientation in me. But this came out of left field because it was not known to do so at the time. My sister had the same problem with it. She didn't know about my taking it, so that seems pretty clear. I got so disoriented driving that I couldn't figure out where I was , even though it was an oft traveled route that I'd traveled for years. The doctor didn't know about this side effect. Now I think there's been some reports of these problems (cognitive difficulties).
The message is that many drugs, not just the usual suspects, can have effect that are unexpected, and it's wise to be on the lookout when taking a new drug.
One explanation for the cholesterol drug causing this is that it messes with the production of various brain chemicals. Cholesterol is used a lot by the brain for good things, it doesn't just clog arteries. Just a word of warning.
Goblu is offline
post #27 of 31 (permalink) Old 05-18-2014, 11:56 AM
Country: India
First Name: Lilly Rowling
Lagta Hai, Ye Saale Saare Ke Saare Apni Maa Ki Tukai Karvaane Aaye Hain...
Hey Guys, I can you understand this reply, if not please tell me, it is written in Hinglish. I will translate.
idioms is offline
post #28 of 31 (permalink) Old 11-19-2014, 06:38 PM
Phil P's Avatar
First Name: Phil
Yes please, translation much appreciated!
Regards
Phil
Phil P is offline
post #29 of 31 (permalink) Old 11-19-2014, 06:41 PM
hahah, Phil.. Lily says she is a school teacher?
Sydney, Australia
jw2170 is offline
post #30 of 31 (permalink) Old 11-20-2014, 12:21 AM
Phil P's Avatar
First Name: Phil
Well, it's all "Dutch" to me, James......
Phil P is offline
All about Power Tools iconlife Tools and Woodworking 10 08-13-2012 01:09 PM
harbour freight power tools? jeep_man Tools and Woodworking 27 05-20-2010 09:35 AM
