Drill press laser device - Page 5 - Router Forums
 52Likes
Closed Thread
post #41 of 46 (permalink) Old 12-08-2015, 10:48 AM
Originally Posted by Quillman View Post
What a pity. Hi tech for the sake of it and it's nuthin' but a guess.
I have to agree with you Pat for several reasons, none of which may be the same as yours. In order to be accurate the lines would have to be very fine which would make them very hard to see, especially in good lighting, which you would need to see the mark where you want the hole drilled. Then there is the question of whether they will stay aligned with the vibration from the DP shaking them constantly. So even though I can see how to make it work I doubt I would find any circumstances where I would be interested in using them.
Gaffboat, Nickp, Semipro and 3 others like this.
post #42 of 46 (permalink) Old 12-08-2015, 02:34 PM
Gaffboat's Avatar
First Name: Oliver
Here's the problem I have with the drill press laser guides. First I calibrated the laser by clamping a piece of stock down on the drill press table and drilling a shallow 1/8" hole. I then calibrated the laser so the cross hairs aligned with the hole. As long as I didn't move the table I could drill multiple holes correctly.
However, when I dropped the table about 2" the laser no longer accurately showed where the center of the hole would be. You can see from the photo that it is off by about 1/16". That probably isn't close enough if you are trying to drill hole in parts that need to align for assembly.
Gaffboat is offline
post #43 of 46 (permalink) Old 12-08-2015, 02:34 PM
Honored Member
First Name: pat
I'm after medium to .001" resolution.
And a laser will not get me there.
And I really don't understand those that say it's (laser) perfect.
For rough work, yes, but even on .005" - .010" centers you're guessin' & hopin', not knowin'.
I know the importance of close order drilling and the consequences if you can't.
Have studied this for a long time. In fact this fence is predicated on being able to drill to
.001". Not only for the hole diameters, centers, and the coordinates for a set of centered holes but their roundness. Absurd for wood, but not for metal and plastic.
And if you make jigs, the essence of precise woodworking, you need metal and plastic substrates.
And therefore, you need the skills, drills and machine to do just that.
CharleyL, Nickp, Stick486 and 2 others like this.
Quillman is offline
post #44 of 46 (permalink) Old 12-08-2015, 06:53 PM
RainMan 2.0's Avatar
Oliver if you can't make it work accurately , there's no way I'm going to get it right lol . Think I'll just get a cnc router table and use it for precise drilling
budiman0416 likes this.
Ok ,I never insulate
RainMan 2.0 is online now
post #45 of 46 (permalink) Old 12-08-2015, 07:58 PM
Ratbob's Avatar
First Name: Jeff
When I need to hit a mark 'right on' I make a clearly visible cross using a ruler and no larger that 0.5mm pencil. Line it up visually from several perspectives and clamp it to the fence. Next I pull the bit down with the DP 'off' making a small impression in the wood. If the peck lines up with the cross-hair, drill the hole. If not, repeat. There is no way that I can get that kind of precision using a laser. The hardest part is accurately marking a precise cross-hair.
Ratbob is offline
post #46 of 46 (permalink) Old 12-13-2015, 12:33 PM
Administrator
Cricket's Avatar
First Name: Cricket
This thread is closed, pending admin/moderator review.
Thank you for understanding.
Need admin assistance? Post here so we can help you!
Cricket is offline
Closed Thread
Benchtop Drill Press Modification JimS Tools and Woodworking 23 07-19-2018 12:51 PM
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Picture of my Drill Press recently finished RLego Tools and Woodworking 5 07-12-2013 03:13 PM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
