Drill press laser device - Router Forums
 52Likes
Closed Thread
post #1 of 46 (permalink) Old 12-06-2015, 07:53 PM Thread Starter
Default Drill press laser device
For people with reduced vision adding one of the aftermarket laser devices to their drill press may help. While the laser lines do not photograph well I can assure you that they are quite bright even with the work light focused on the tiny hole they are centered on. This could also save on set up time for everyone.
How many of you have/use the drill press laser devices?
Name:	Ptree Laser.jpg
ksidwy, Murtu01 and RainMan 2.0 like this.
post #2 of 46 (permalink) Old 12-06-2015, 08:01 PM
RainMan 2.0's Avatar
Mike I'd love to have a laser on my drill press . I didn't know they made aftermarket systems, and wonder if it will fit that beast of mine ?
Ok ,I never insulate
RainMan 2.0 is offline
post #3 of 46 (permalink) Old 12-06-2015, 08:01 PM
JFPNCM's Avatar
First Name: Jon
@Mike
I've looked at them in the store but no experience.
Can you mention the manufacturer in your photo? Comments regarding difficulty to set them up, stability of the image over time etc will be appreciated.
Jon
JFPNCM is offline
post #4 of 46 (permalink) Old 12-06-2015, 08:13 PM
turned them or removed them all together...
post #5 of 46 (permalink) Old 12-06-2015, 08:19 PM
Semipro's Avatar
First Name: John_*
aftermarket
DRILL PRESS LASER GUIDE BY PEACHTREE WOODWORKING PW929
rcp612 and RainMan 2.0 like this.
Semipro is offline
post #6 of 46 (permalink) Old 12-06-2015, 08:19 PM
First Name: Mark
Have one (buit in), used it a couple times, don't trust it - it comes close but not totally accurate. it varies with the thickness of the wood, position of the table
DaninVan, MEBCWD and Murtu01 like this.
FreeTime is offline
post #7 of 46 (permalink) Old 12-06-2015, 08:25 PM
Thanks John . Looks like it will fit mine no problem , at least I believe so anyways now that I see how it works.
I always wondered how they project a laser when the chucks in the way , but now I understand how they pulled it off by using two lasers mounted off to the side
http://www.amazon.com/DRILL-PRESS-LA...ct_top?ie=UTF8
post #8 of 46 (permalink) Old 12-06-2015, 09:48 PM Thread Starter
Rick, the model I installed is from Peachtree and I am sure it would work on your drill press. It came with two different sized clamps so it could fit different machines.
Jon, it took about 30 minutes to get the lasers dialed in. There are two adjustments on each laser and it is easy for one adjustment to drift while adjusting the other.
Mark, I wonder if the beam direction and angle are fully adjustable on your drill press? Could you please post a photo of the laser housing? This is a learning experience for all of us. If the location varies at different table heights I suspect the beam angle is not perfectly vertical.
I will get a couple of close up photos of the right laser head showing how the adjustments are made and the alignment tool.
ksidwy likes this.
post #9 of 46 (permalink) Old 12-06-2015, 09:56 PM
Ok I never thought it going out of alignment when you change the table height .
That would certainly be a deal breaker
JFPNCM, Nickp, Stick486 and 1 others like this.
post #10 of 46 (permalink) Old 12-06-2015, 10:27 PM
According to the photo that you showed Mike they can't possibly be shining vertically. They are about 3 " to either side. Since there is parallax involved you would have to do as Mark said and refocus every time you moved the table up or down. If it takes 30 minutes every time you do that it would be a terrible PITA.
paduke, Nickp and budiman0416 like this.
Closed Thread
Benchtop Drill Press Modification JimS Tools and Woodworking 23 07-19-2018 12:51 PM
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Picture of my Drill Press recently finished RLego Tools and Woodworking 5 07-12-2013 03:13 PM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
