Bandsaw Light - Page 3 - Router Forums
 23Likes
post #21 of 45 (permalink) Old 12-10-2015, 10:49 AM
Garyk's Avatar
First Name: Gary
I use task lighting with the "old" fashion rough duty bulbs. The LED's don't show shadows which can be a problem when turning on the lathe. I use both the magnetic base and the clamp type depending on the machine. Vibration makes the decision.
I'll check out the ones Jeff mentioned, they look interesting.
Garyk is offline
post #22 of 45 (permalink) Old 12-10-2015, 10:54 AM
Ratbob's Avatar
First Name: Jeff
Originally Posted by David Dickson View Post
Funnily enough, I just bought this LED light with a magnetic base today. Found it in my local tool sales / repairs shop in Aldershot, UK. It cost me the princely sum of £5.99 (about $9). I haven't had the chance to try it out while actually cutting on the bandsaw, but it looks good so far.
David, before I found the Dorcy I was using a freebie from Harbor Freight that was much like the one you purchased. It worked great except the fence would cast a shadow over the blade when doing narrow cuts. Hope it works better for you!
Ratbob is offline
post #23 of 45 (permalink) Old 12-10-2015, 01:30 PM
neville9999's Avatar
First Name: Neville
Send a message via Yahoo to neville9999
Originally Posted by gjackson52 View Post
I hope this is the right place for the question. I am finding that as I get older, I need more and more light to be able to do the things I could do while I was younger. Is anyone using a bandsaw light they like ?
Thanks....Gary
You need lights on all the machines Gary, as I get older then I need more light. N
gjackson52 likes this.
neville9999 is offline
post #24 of 45 (permalink) Old 12-13-2015, 08:02 AM
First Name: Art
What I found to work the best for me as well as being the cheapest is a goose neck desk lamp that got from Goodwill for $1.00. I attached it to the ceiling above the saw with one screw through the base. I can point it in any direction that I want and often do so when I need the light on something else . I have a similar set up above the table saw only with that light I use a floodlight bulb.
Name:	bandsaw light.jpg
gjackson52 and Chris Hachet like this.
mgmine is offline
post #25 of 45 (permalink) Old 12-13-2015, 12:34 PM
First Name: David
Lightbulb
Jeff, You had me worried for a moment, so I just popped out to the garage - I mean the workshop - and checked. The yellow blade guard is ferrous, so the lamp sticks to that and provides sufficient illumination to cut featherboards. Only minor concern is if the lamp should become dislodged, it is right in line with the blade. Think I'll put a string through the handle and attach the other end to the side of the bandsaw, so that if the lamp comes loose, it will swing out to the side and not drop into the blade.
David Dickson is offline
post #26 of 45 (permalink) Old 12-13-2015, 02:53 PM
Ratbob's Avatar
First Name: Jeff
Glad it worked out for you David.
Ratbob is offline
post #27 of 45 (permalink) Old 02-13-2016, 09:18 AM
First Name: dave
i use the magnetic lights on my drill presses, bandsaw, they work very well, i use the energy saving bulbs, the regular bulbs i feel put out to much heat.
davefrommd is offline
post #28 of 45 (permalink) Old 02-13-2016, 03:16 PM
First Name: Keith
Clicked on the original Amazon link...lights still available...but do not ship to Canada. We get this all the time and it's damn annoying.
Checked on Amazon.ca and found a similar light for a couple of $ more, but that is much less than $12.99 U.S. Free shipping as well, so I win twice. Bought two, one for the drill press, one for the bandsaw.
OK, fess up...which one of you clowns stole my sig? It was right here a second ago.
cocobolo1 is offline
post #29 of 45 (permalink) Old 02-13-2016, 04:47 PM
move or get a second address...
post #30 of 45 (permalink) Old 02-13-2016, 07:48 PM
Originally Posted by Knot working View Post
My band saw is equipped with a light, but when I converted the saw to 220 I can't use the light.
Is there a bulb that can be used with 220?
Larry; another solution to the 220V issue...
http://www.amazon.ca/Ckeyin-110V-120...110v+converter
DaninVan is offline
Bandsaw Economics Of Cutting Rough Timber Gaia Tools and Woodworking 22 07-13-2012 06:40 PM
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 09:47 AM
Help with a LDR Light Dark Relay. Any electricians here? unlimitedwoodworker Lobby 5 09-03-2008 11:50 PM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
