Bandsaw Light - Page 4 - Router Forums
 23Likes
post #31 of 45 (permalink) Old 02-13-2016, 08:00 PM
Originally Posted by Knot working View Post
My band saw is equipped with a light, but when I converted the saw to 220 I can't use the light.
Is there a bulb that can be used with 220?
sure ya can...
just use one leg of the 220V feed for power and supply a neutral for the other leg...
Chris Hachet likes this.
post #32 of 45 (permalink) Old 02-13-2016, 08:06 PM
http://www.amazon.com/s?ie=UTF8&page...0Light%20Bulbs
post #33 of 45 (permalink) Old 04-01-2017, 09:56 PM
First Name: Tony
I know this is an old thread just thought I'd post my solution to the light problem, I had an old broken bench grinder that had a flexible light on it so I took it off of it before I trashed it. Wired it directly into the band saw power box and bingo light comes on with power or by it's own switch....almost looks factory too....
gjackson52 likes this.
comp56 is offline
post #34 of 45 (permalink) Old 04-02-2017, 12:17 AM
@gjackson52 This is how I handled the light on my big bandsaw. I too really need lots of light these days. The light is on here, but I wanted to show the LED spotlight that goes into it. I purchased an inexpensive fixture, then mounted a circular electrical box in the existing holes on the side of the saw, and installed a small toggle switch in the box. The cable goes to an electric plug on the back post of the saw. This is a very bright light! But being an LED, it doesn't get hot.
Name:	bandsaw light.jpg
post #35 of 45 (permalink) Old 04-02-2017, 10:45 AM
CharleyL's Avatar
First Name: Charley
Duplicate post - removed. See my second post
Central North Carolina
CharleyL is offline
post #36 of 45 (permalink) Old 04-02-2017, 11:11 AM
CharleyL's Avatar
First Name: Charley
The attached light is available from Lowes for $19.97 and may be available elsewhere.
https://www.lowes.com/pd/Style-Selec.../1000003084bbb
I've found them to produce a nice bright and very white, shadow free light without getting more than just mildly warm after being on for several hours, so no more head, face, and arm burns. The rubber lined spring clamp holds very well to anything that is about 1" thick. I now have these on several of my tools including my band saw, grinder, belt sander, one drill press, two on my DeWalt scroll saw, and I have several more that move around the shop wherever I need extra light. I removed the spring clamps from two of them and attached them to a bracket that fits around the upper arm of my scroll saw so I have one of these lights mounted on each side of the upper arm. Light from both sides of the blade completely eliminates blade shadows, making it much easier to cut tiny work more accurately.
Lowes also sells this light with a weighted base instead of the clamp for the same price. If you are planning to remove the clamp and attach the light and goose neck to a shop made bracket, do not purchase the weighted base version, as the bottom end of the goose neck is different and it will be much more difficult to use it. The end of the goose neck on the clamp version is threaded and attached to the clamp with a lock washer and nut, so you only need a hole in your bracket to attach it.
Charley
Name:	0Shop Light 22011643083.jpg
CharleyL is offline
post #37 of 45 (permalink) Old 04-06-2017, 12:28 PM
First Name: N/aChris
Originally Posted by mgmine View Post
What I found to work the best for me as well as being the cheapest is a goose neck desk lamp that got from Goodwill for $1.00. I attached it to the ceiling above the saw with one screw through the base. I can point it in any direction that I want and often do so when I need the light on something else . I have a similar set up above the table saw only with that light I use a floodlight bulb.
One of the real benefits of a basement shop....with 10 foot ceilings, this would not work so well for me.
Chris Hachet is offline
post #38 of 45 (permalink) Old 04-06-2017, 12:30 PM
sure ya can...
having a neutral with a 220 circuit is a nice simple upgrade.
Besides, if I ever upgrade the shop with a rotary phase converter, I then have another conductor to run a three phase tool...
post #39 of 45 (permalink) Old 04-06-2017, 07:09 PM
BrianS's Avatar
First Name: Brian
I solved this problem by purchasing one of these: Delta light It has a magnetic base, so can be easily moved to other tools if needed. I know, this is the Canadian side of Amazon, but I'm sure it's available on .com as well.
Brian
(Origin uncertain)
BrianS is offline
post #40 of 45 (permalink) Old 04-12-2019, 05:20 PM
sgcz75b's Avatar
First Name: Steve
I realize this is an old thread, but if you want an inexpensive 6 watt LED light that provides good light, has a magnetic base that sticks fast to even thin vertical sheet metal, flexible gooseneck, and for less than 12 dollars, look at this one.
I have three; one on a drill press, and two on my bandsaw (one positioned below the table to see to adjust guides and bearings).
Small enough to not be in the way, yet bright enough to work nearly anywhere in the shop.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
"What can be asserted without proof can be dismissed without proof." Christopher Hitchens
sgcz75b is offline
Bandsaw Economics Of Cutting Rough Timber Gaia Tools and Woodworking 22 07-13-2012 06:40 PM
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 09:47 AM
Help with a LDR Light Dark Relay. Any electricians here? unlimitedwoodworker Lobby 5 09-03-2008 11:50 PM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 02:22 AM
