Bandsaw Light - Page 5 - Router Forums
 23Likes
post #41 of 45 (permalink) Old 04-19-2019, 12:07 AM
First Name: lee
Originally Posted by Chris Hachet View Post
having a neutral with a 220 circuit is a nice simple upgrade.
Besides, if I ever upgrade the shop with a rotary phase converter, I then have another conductor to run a three phase tool...
I guess to add a neutral you need to go to a 4 prong plug? I don't know if it would be code to use ground for neutral. It would probably run.
coxhaus is offline
post #42 of 45 (permalink) Old 08-04-2019, 06:55 AM
mr happymoose's Avatar
First Name: Jon
Here's how I solved the problem. My work space is shall we say...tight and my band saw has to sit on my workmate which only has one place it can go. This particular spot is of course just right to cast shadow from both lights in the garage. Whilst lost in Ikea one day I spotted their JANSJÖ USB powered spotlights which were just a couple of quid. To be honest I wasn't expecting much for the money but I was actually very surprised with the light output. A bit of sticky back velcro and a cheap USB powerbank and it was all sorted. Total cost with one light and the powerbank was about £6 if I recall correctly and I can also use it anywhere else I need a bit of extra light.
jj777746 and gjackson52 like this.
Tryin' Hard
mr happymoose is offline
post #43 of 45 (permalink) Old 08-04-2019, 02:37 PM
Knothead47's Avatar
I have a benchtop BS and DP, right next to each other. The flex light on the DP doubles as a light for the BS.
Herb Stoops likes this.
John T.
Life is like water-skiing; if you slow down, you go down.
Knothead47 is offline
post #44 of 45 (permalink) Old 08-04-2019, 08:56 PM
My small band saw needed a light, so I got a gooseneck lamp from Goodwill, dismantled it and drilled a larger hole in an L bracket, screwed the base of the gooseneck into it. Drilled two small holes in the upper wheel case, bolted the other end of the L bracket in and strung the power cord around to a plug. Works really nicely. Put an LED spot into it and voila. High visibility. Out of the way. Cost about a buck.
Name:	light on Rikon 12.jpg
gjackson52 likes this.
DesertRatTom is online now
post #45 of 45 (permalink) Old 08-05-2019, 05:38 PM
Knothead47's Avatar
DRT, and I thought I was cheap! Good idea, though.
John T.
Bandsaw Economics Of Cutting Rough Timber Gaia Tools and Woodworking 22 07-13-2012 07:40 PM
Looking at buying a bandsaw... frootloops Tools and Woodworking 5 06-22-2009 10:47 AM
Help with a LDR Light Dark Relay. Any electricians here? unlimitedwoodworker Lobby 5 09-04-2008 12:50 AM
Grizzly GO636X 17" Ultimate Bandsaw GoonMan Tool Reviews 1 07-27-2008 03:22 AM
