Help shaping a wood slat for VW bed - Router Forums
 3Likes
  • 2 Post By fire65
  • 1 Post By paduke
post #1 of 8 (permalink) Old 11-30-2016, 02:49 PM Thread Starter
Default Help shaping a wood slat for VW bed
Hello,
I am replacing the wood bed slats in a VW double cab truck. Hopefully the images and sketch of the slat shows up. Each slat is 1 1/2" wide X 5/8" thick. I'm having trouble figuring out how to cut the curve on the top of each slat. I was hoping I could find a router bit but really am stumped.
Thank you,
MokieDokie
Name:	Screen Shot 2016-11-30 at 12.34.38 PMNov 30, 2016.png
MokieDokie is offline
post #2 of 8 (permalink) Old 11-30-2016, 03:15 PM
Knothead47's Avatar
Can't help you with your question but that truck is a real collector's item. Have a friend who had 9 VWs to restore in his retirement.
Pickers found a lot full of various VWs one of which was the rare 23 window edition; windows all around the VS bus.
Fellow that my dad worked with in the early 60s had a VW bus and called it his Elephant.
John T.
Knothead47 is offline
post #3 of 8 (permalink) Old 11-30-2016, 03:43 PM
First Name: Clay
I think a finger nail bit is what you need. There are several different sizes, you will just have to do some measuring to find the right one.
fire65 is offline
post #4 of 8 (permalink) Old 11-30-2016, 03:54 PM
Honored Member
First Name: pat
60 first, both corners. Then the thumb nail.
Beautiful wagon, oak flooring will add soul.
Use a better fastener, however. Sheet metal with a prettier head (pan flange socket) in SS.
Quillman is offline
post #5 of 8 (permalink) Old 11-30-2016, 06:44 PM
Welcome to the forum Mokie. Most of the major bit makers make the bit Clay pictured.
post #6 of 8 (permalink) Old 11-30-2016, 06:53 PM
paduke's Avatar
suggest using in a router table
Cherryville Chuck likes this.
paduke is offline
post #7 of 8 (permalink) Old 12-01-2016, 10:48 AM Thread Starter
Hi Quillman...Thanks for the excellent suggestion, especially trimming the slat edge at 60 degrees before using the fingernail bit.
The slat image is the original way VW attached the slats...4.4mmX16mm sheet metal screw without plugs or recess. The other way was using pop rivets. I'll be doing the sheet metal screws, but they'll be stainless. I'll look for your screw suggestion...
Thanks again...
Dennis
post #8 of 8 (permalink) Old 12-01-2016, 10:55 AM
I tried some stainless screws that Lee Valley sold and I couldn't keep them tight. The smooth surface allowed them to back out easily. Maybe Spax screws would hold better? They have serrations around the edges of the threads that might grip better. STAINLESS STEEL SCREWS
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 04:01 PM
Choosing the best wood for outdoor projects Hamlin Wood Species 5 07-21-2009 07:40 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
How to identify wood species: allthunbs Tools and Woodworking 11 12-04-2008 12:28 PM
