Need help with wobbly bench! - Router Forums
 30Likes
post #1 of 15 (permalink) Old 02-23-2017, 05:25 PM Thread Starter
MLR
Default Need help with wobbly bench!
I need help badly. After putting this bench together and sitting it upright it wobbles like crazy. The wood is not the best (from Lowes) so I know every board is not milled properly. Anyone have any tips on how I would go about trimming the legs evenly? Thanks for your time!
Matt
MLR is offline
post #2 of 15 (permalink) Old 02-23-2017, 05:57 PM
Move it around and see if your floor is flat. If it is setting where you want it and it is out diagonally, shim the two diagonal legs equally til it doesn't rock. Then take a shim the thickness of what you shimmed the diagonal legs and mark the other 2 legs and trim them off . It should be flat after that.
Herb Stoops is online now
post #3 of 15 (permalink) Old 02-23-2017, 08:18 PM
JOAT's Avatar
First Name: Theo
I learned long ago how to get around that. Make a rocking chair. Or, make a three legged chair. Either way, no teetering, and loads of stress saved.
ksidwy and Herb Stoops like this.
JOAT is online now
post #4 of 15 (permalink) Old 02-23-2017, 08:59 PM
First Name: lee
Nice heavy bench. I think you are going to have to shim or cut to fit the floor. If you are going to move it much then I would shim it.
I would bevel the feet kind of like the top edges. It will keep the legs from chipping.
coxhaus is offline
post #5 of 15 (permalink) Old 02-23-2017, 10:18 PM
vchiarelli's Avatar
First Name: Vince
Before you start modifying your bench, find a flat spot, maybe on another floor and see if it is the bench or your cement floor.
vchiarelli is offline
post #6 of 15 (permalink) Old 02-24-2017, 12:50 AM
sunnybob's Avatar
Country: Cyprus
First Name: Bob
Squares of heavy duty rubber under each leg. No more wobble and waterproof as well.
Available as "anti vibration motor mounts".
sunnybob is offline
post #7 of 15 (permalink) Old 02-24-2017, 11:18 AM
Country: South Africa
First Name: Paul
If the bench is not always in fixed position I would attach levelers to each leg then its just a matter of screw/unscrew to get level before each use. Eg
PaulH is offline
post #8 of 15 (permalink) Old 02-24-2017, 11:46 AM
Welcome to the forum MLR.
post #9 of 15 (permalink) Old 02-24-2017, 11:50 AM
MT Stringer's Avatar
I fixed your picture.
Name:	Matts Bench.jpg
ksidwy likes this.
MT Stringer is online now
post #10 of 15 (permalink) Old 02-24-2017, 04:35 PM
First Name: Quenten
Is the bench not meeting the floor the problem, or is the actual bench itself wobbling? As in loose fitting joints? Can you post a picture of the underside so we can see how it's put together?
Tonto1 is offline
Modified bench top saw horses Gaffboat Show N' Tell 5 01-05-2017 04:25 PM
Add-on Bench berry Tools and Woodworking 13 07-16-2015 12:24 AM
Bench Dog BenchTop vs. The Super Bench, Bench Top Router Table emergencyshutdown Table-mounted Routing 8 11-14-2011 01:58 AM
Bench Dog 40-016 ProLift Max Dejure Tool Reviews 1 08-04-2009 04:26 AM
