Replacement blades for old Craftsman jointer - Router Forums
 1Likes
  • 1 Post By Cherryville Chuck
post #1 of 5 (permalink) Old 03-06-2017, 08:54 PM Thread Starter
First Name: Larry
Default Replacement blades for old Craftsman jointer
I have an old Craftsman jointer, 4 3/8" blades/knives that need replacement.
Suggestions please. It's Model 103.23340. Sears is no help---out dated.
luxlarry is offline
post #2 of 5 (permalink) Old 03-06-2017, 10:09 PM
Normally the blades aren't proprietary, they are just some stock blade.Take the old ones and measure the thickness and width. You can find sellers that will cut to the right length if necessary. Here's just one example. globaltooling.net
Roy Drake likes this.
post #3 of 5 (permalink) Old 03-07-2017, 06:02 AM
hawkeye10's Avatar
First Name: Don
I am pretty sure you can have those blades sharpened. I read that Woodcraft was a good place to send blades but it may cost almost as much to get them sharpened as new blades. Either way I don't think you will have much of a problem.
If you have not installed blades in a jointer that may be a problem. They can be a bugger. Go to You Tube and there are several good videos on how to do it. You can also ask questions here. That is why this forum is here, but you know that.
Don in Murfreesboro,Tn.
hawkeye10 is offline
post #4 of 5 (permalink) Old 03-07-2017, 08:56 AM
Don is right in that small blades like those might be cheaper to just replace. Resetting them can be finicky but it's not hard. This is the method I use. Setting Jointer Knives | Free Woodworking Advice
If you have the gauge that should have come with the jointer it will give you the approximate amount of knife that should be exposed above the knife head. However, it won't give you the actual final adjustment. You have to adjust the outfeed table for that. If you haven't moved the outfeed table since the old blades came out you can use the hardwood to block to set the height of the blades.
post #5 of 5 (permalink) Old 03-14-2017, 03:47 PM Thread Starter
First Name: Larry
Thanks---I'm heading back into the garage.
luxlarry is offline
Craftsman Router replacement switch BobBratton General Routing 12 12-19-2012 07:49 AM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 17 10-11-2012 05:20 PM
dust extraction for craftsman routers headclansman General Routing 2 08-01-2009 10:29 AM
craftsmen router? rhe8542 Starting Off 21 04-20-2009 10:51 PM
Sold: Craftsman Jointer 4 3/8 in (almost free) kp91 Woodworking Classifieds 2 04-20-2009 05:34 PM
