Need expert suggestions for table - Router Forums
 4Likes
post #1 of 12 (permalink) Old 11-01-2017, 12:02 PM Thread Starter
Default Need expert suggestions for table
Hi. I have an old 5 ft. dia. oak table top that I so far have been unsuccessful in finishing. I want to use a satin varathane; the problem is that it has a large carved out (or routered) section in the center of the top; the varathane drips into the carved areas and when I try to brush the excess out, it ruins the smooth, with the grain surface I am trying to achieve. I thought about trying to begin at the center with a smaller brush, then working with a larger brush, with the grain to the edge and going around the table in that fashion (instead of going completely across the whole diameter as I did originally). The problem is that when I get around to the beginning point, the varathane there will be more dry. Would it leave an uneven noticeable area where the drier and wetter areas join? Is there any way of solving this dilemma short of having it professionally sprayed? Is there something I could fill the carved out areas with, that I could later remove when the top is dry, to keep the varathane from dripping in? Thank you so much for any help that can be offered. (Photo inserted.)
gdf103 is offline
post #2 of 12 (permalink) Old 11-01-2017, 10:36 PM
Welcome to the forum. Years ago varnish took 16 to 24 hrs to dry and this wasn't a problem at least according to my memory. It became a problem with fast drying finishes. Anything I've tried to touch up after a few minutes looked like crap as it showed brush marks. The older, slower drying finishes had time to self level. If you can find one that is hours to dry it might do what you want. Otherwise try wiping on or spray.
post #3 of 12 (permalink) Old 11-01-2017, 11:29 PM
First Name: lee
You might try rubbing out the carved out areas with a rag. Then brush them separate with a small brush. I would use wipe on poly myself.
MEBCWD likes this.
coxhaus is offline
post #4 of 12 (permalink) Old 11-01-2017, 11:46 PM
Pounamu's Avatar
Country: New Zealand
First Name: Keith
Send a message via AIM to Pounamu Send a message via Skype™ to Pounamu
I agree with this suggestion. Welcome to the forum.
MEBCWD and gdf103 like this.
If eating carrots improves the eyesight, how come there are so many dead rabbits on the roads?
Pounamu is offline
post #5 of 12 (permalink) Old 11-02-2017, 10:30 AM
First Name: Barry
Wipe on poly with a number of thin coats. It's relatively fast drying and, using thin coats, would have less of a tendency to run into the grooves. You can make your own by taking regular poly and thinning 50/50 with mineral spirits. There's no rule that it has to be 50/50 but you can start there and adjust. The thicker it is the longer it will take to dry and may run. The thinner it is, more coats will be necessary. This is one of those things that, for your project, may take a little trial and error. Hopefully, not too much error. Let us know what works for your project.
harrysin likes this.
Barry747 is offline
post #6 of 12 (permalink) Old 11-05-2017, 11:59 PM Thread Starter
Hi, thanks so much for your reply. Your suggestion sounds good. I have had trouble lately finding any genuine mineral spirits. Would it matter if it was just regular paint thinner? Have you are anyone had success with that?
gdf103 is offline
post #7 of 12 (permalink) Old 11-06-2017, 12:01 AM Thread Starter
Thank you so much!
gdf103 is offline
post #8 of 12 (permalink) Old 11-06-2017, 12:05 AM Thread Starter
Your suggestion is good and I will do some research on it! Thank you!
gdf103 is offline
post #9 of 12 (permalink) Old 11-06-2017, 03:32 AM
First Name: lee
I buy my mineral spirits at Sherwin Williams in a 5 gal barrel which is the cheapest I can find.
coxhaus is offline
post #10 of 12 (permalink) Old 11-06-2017, 08:16 AM
RouterForums.com User
harrysin's Avatar
First Name: Harry
Definitely NOT thinners, over many years I've used whatever turpentine I Happened to have and never found a difference.
Harry
harrysin is offline
Suggestions for a new bench please darsev Workshop Showroom 32 11-17-2014 04:43 AM
Suggestions on finishing dollhouse bradinc DIY and Renovation 4 06-24-2014 08:16 PM
Router table suggestions appreciated jnahman New Member Introductions 16 11-03-2012 12:28 AM
shape suggestions for transitions etc. mtnmaniac General Routing 3 08-25-2010 12:17 AM
Ideas / Suggestions Mark Lobby 4 09-20-2004 07:55 PM
