Rotacator advice - Router Forums
 4Likes
  • 2 Post By DaninVan
  • 1 Post By Terry Q
  • 1 Post By JFPNCM
post #1 of 8 (permalink) Old 12-15-2017, 02:23 PM Thread Starter
First Name: Quenten
Default Rotacator advice
Hey fellows, if you've following my progression (which I certainly don't expect), I have an 8" Grizzly Jointer, a 15" Grizzly Planer and the lowly 10" Hitachi Table Saw. I have found several rotacators, but, of course have no experience with them. So once again I'm here seeking your expert advice. These are some of the models I have been looking at. A unit that can be used on all three would be ideal!
This looks like the one Grizzly sells for the planer, don't know how it would work out on the table saw.
https://www.amazon.com/Woodstock-Win...SIN=B0000DD0P0
Grizzly also makes this one, very inexpensive but gets mostly ok reviews.
https://www.amazon.com/dp/B0000DD0VA...et_detail_page
This one is a precision square as well.
https://www.amazon.com/Oneway-2289-M...SIN=B0002SA98I
This one looks like it would work great on the table saw. It of course has an aluminum table, so I don't know how the others would work out.
Woodpeckers | Saw Gauge (SG-WP)
And feel free to lead me to another option. As always, thanks in advance for all the help you guys have given me!
Tonto1 is offline
post #2 of 8 (permalink) Old 12-15-2017, 03:45 PM
Never heard that expression, Rotacator, before...
Unless you're making precision parts for the aerospace industry, the less expensive models will work just fine. The only part that's critical is the gauge itself. Buy the less expensive model; you can always buy up if you're really unhappy with it. It's not like buying quality with carbide tools or electronics. Just my opinion. I've got a cheap one and it works well...my machinist buddy did a bit of set-up work for me, using it, and he had no complaints.
* The Grizzly one looks identical to mine. Same price range taking the $Cdn. exchange rate into account.
thomas1389 and mgmine like this.
DaninVan is offline
post #3 of 8 (permalink) Old 12-15-2017, 04:29 PM
Terry Q's Avatar
I hope you come up with a one-gauge-fits-all solution, because it certainly would be helpful. I use the oneway model for my jointer, but it wonít work with my planer. The gauge needed for a table saw needs to run off the miter slot to make sure it is parallel with the blade, for that I bought the woodpecker model, but it doesnít help with the planer either.
The planer is the hard one since they arenít all built the same and there is no easy way to reference from a flat surface. For my planer I use the silly manual gauge that came with my planer that references off the curved head since I canít come up with something better.
DaninVan likes this.
Terry Q is offline
post #4 of 8 (permalink) Old 12-15-2017, 05:25 PM
I don't use anything like that for planer or jointer. It might help a bit with the planer but the thing that's critical with the jointer is getting the blades set flat in relation to the beds and then setting the outfeed table to the right height in relation to the blades. The gauge won't necessarily help with that. I usually just use a caliper as a depth gauge to set the TS although that would be a bit more accurate. And I do have one like the Grizz. I think it's a Tek Lok which were really popular here at one time. Might be the same one that Dan has.
post #5 of 8 (permalink) Old 12-15-2017, 07:38 PM Thread Starter
First Name: Quenten
Thanks guys, always a pleasure.
Tonto1 is offline
post #6 of 8 (permalink) Old 12-16-2017, 12:35 PM
JFPNCM's Avatar
First Name: Jon
@DaninVan
Labeling, Dan, labeling. Calling it a "rotacator" means you can charge more. Check the price differences.
Cherryville Chuck likes this.
Jon
JFPNCM is offline
post #7 of 8 (permalink) Old 12-16-2017, 02:39 PM
Originally Posted by JFPNCM View Post
@DaninVan
You might be right. When mountain pine beetles started killing trees off up here there was a lot of the lumber to get rid of. The beetles carry a fungus that turns the sapwood blue and they couldn't get rid of it a decent price. Until someone re-labelled it "denim pine". Then they starting charging more than if it wasn't blue.
post #8 of 8 (permalink) Old 12-16-2017, 05:04 PM
JFPNCM's Avatar
First Name: Jon
@Cherryville Chuck
Some people refer to that as "marketing". We also referred to it as "smoke and mirrors".
Jon
JFPNCM is offline
