Quick Course in Electricity - Router Forums
 76Likes
post #1 of 28 (permalink) Old 01-12-2018, 02:41 AM Thread Starter
Default Quick Course in Electricity
Study this and then take the test for journeyman.
Herb Stoops is online now
post #2 of 28 (permalink) Old 01-12-2018, 08:36 AM
DonkeyHody's Avatar
First Name: Andy
That's well put. I've always used the analogy of water in a pipe, which I can understand intuitively. But when trying to use the analogy with others, I find that a lot of people, even a lot of engineers, don't have an intuitive understanding of electricity in a circuit or water in a pipe either.
DonkeyHody is offline
post #3 of 28 (permalink) Old 01-12-2018, 12:36 PM
JFPNCM's Avatar
First Name: Jon
Andy:
Good points. The real difference is that water leaks, electricity doesn't.
DaninVan likes this.
Jon
JFPNCM is offline
post #4 of 28 (permalink) Old 01-12-2018, 12:42 PM
That's always the analogy I've used too Andy. Water is like the amp and the pipe pressure is like the voltage and pipe size and elbows and changes in diameter is like the ohm. There are a few correlations to it such as adding a wire to a circuit is like adding a tee to a water line and going up a wire size or pipe size makes it flow easier.
The problem with trying to explain lots of things I've noticed has nothing to do with how simple it is. It has to do with how complex the person you are explaining it to thinks the problem is. The more complex they think it is, the less likely they are to understand your explanation.
post #5 of 28 (permalink) Old 01-12-2018, 01:02 PM Thread Starter
Your analogy works for airflow in Dust Collection too, Chuck.
Cherryville Chuck likes this.
post #6 of 28 (permalink) Old 01-12-2018, 01:33 PM
MT Stringer's Avatar
I have always had trouble with electricity. Even spending 33 years working in operations at a chemical plant. The electrical part was difficult to understand, until the lights went out!
Piping and flows were no problem. If need be, I could always follow the piping to see where it started and where it ended, but not the electrical part. Mostly I was happy when the emergency generator started during the monthly test.
Herb Stoops likes this.
MT Stringer is offline
post #7 of 28 (permalink) Old 01-12-2018, 03:27 PM
Everybody wishes they HAD paid attention when the HW tank starts leaking...
DaninVan is offline
post #8 of 28 (permalink) Old 01-12-2018, 03:39 PM
TenGees's Avatar
First Name: Paul
Originally Posted by JFPNCM View Post
Andy:
Corona discharge?
harrysin, DesertRatTom and ggom like this.
TenGees is offline
post #9 of 28 (permalink) Old 01-12-2018, 04:18 PM Thread Starter
[QUOTE=TenGees;1776146]Corona discharge?[/QUOT
When I lived next to the power line right of way, You could stand under the power lines and hold a florescent tube overhead and it would light up.
post #10 of 28 (permalink) Old 01-12-2018, 06:32 PM
artman60's Avatar
First Name: Artie
What’s black, crisp, and hangs from a chandelier? An inept electrician.
The clock of life is wound but once.
artman60 is online now
QUICK bit changes? The Hobbyist Table-mounted Routing 18 07-17-2015 10:53 AM
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 10:33 AM
Quick Release Drill Chuck Won't Release greenacres2 Tools and Woodworking 7 01-06-2015 08:25 PM
Quick hello! PeteW New Member Introductions 9 10-22-2013 10:27 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 01:56 PM
