Mounting vintage wood vise to workbench top - Router Forums
 3Likes
  • 3 Post By vchiarelli
post #1 of 4 (permalink) Old 04-28-2018, 01:01 PM Thread Starter
First Name: JIM
Default Mounting vintage wood vise to workbench top
I bought at an auction a vintage vise. Being a newer woodworker, I am not sure of the best way to mount it. Originally I was going to bury the mounting bracket in the the bench top. However the mounting bracket corner is not a 90 degree angle and cannot be mounted flush to the side of the bench top. Any suggestions on the best way to mount this vise will be greatly appreciated.
jim smith 1950 is offline
post #2 of 4 (permalink) Old 04-28-2018, 04:21 PM
vchiarelli's Avatar
First Name: Vince
@jim smith 1950
Wow, Jim, your second post in 8 years - welcome back.
The back bracket doesn't form a 90 degree angle because, generally, the jaws are splayed inward at the top so that, when clamping force is applied, the top of the jaws will close tightly, without racking outward.
I can't tell from your picture, but there must be mounting holes in the back bracket which allow you to screw the bracket from the underside of the bench - you would have to probably add a filler piece to ensure the top of the jaws is level with your bench top. One or two pieces of plywood would probably suffice, but again it depends on the distance from the flat portion of the back bracket, to the top of the rear jaw, including the thickness of your bench top.
thomas1389, Shop guy and jj777746 like this.
vchiarelli is offline
post #3 of 4 (permalink) Old 04-28-2018, 08:37 PM
jj777746's Avatar
@ jim smith 1950, Hi jim,I had the same problem not so long ago & ended up drilling holes & using 4/ 3 inch lag bolts.Solid as a rock. Jamesjj
You can't drive a bridge spike with a tack hammer(so I'm told)
jj777746 is online now
post #4 of 4 (permalink) Old 04-29-2018, 09:44 AM
First Name: Gary
Jim, If you don't want to carve the edge of your bench to conform to the angle of the rear face of the vise so it will inset into the bench...you could easily shape a shim to conform to the vice angle to fit between the vise and the bench edge. A maple shim would be my choice. I use hard maple for the jaw material covered with cork (easily replaced).
gmercer_48083 is offline
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 05:01 PM
Best wood/ grain hiding technique for jewelry box top rstermer The Finishing Touch 3 05-03-2008 12:57 PM
Solid wood top vs Phenolic insert Drugstore Cowboy Table-mounted Routing 33 03-21-2008 09:39 PM
mounting a light duty vise question... reikimaster Tools and Woodworking 9 09-20-2007 02:42 PM
New Table Top and Wood Rack GoonMan Show N' Tell 9 11-20-2005 12:17 AM
