router problem - Router Forums
 1Likes
post #1 of 12 (permalink) Old 06-07-2018, 02:44 PM Thread Starter
Default router problem
Hello everyone new here. I was given a Milwaukee 5625-29 router. My cousin said he thought the switch was bad because you turn it on it comes on this immediately goes off. I put a different switch on it same thing. The brushes are arching on the armature. Is there anything I can do before taking it to a repair shop?
lewis1952 is offline
post #2 of 12 (permalink) Old 06-07-2018, 02:49 PM
difalkner's Avatar
First Name: David
Welcome to the forum, Lewis! When you get a minute go ahead and complete your profile with first name and location.
I'm not familiar with that router; does it have a speed control? If so I wonder if the circuitry has gone bad. How badly are the brushes arcing?
David
David
Curly Wood Shop on Etsy
Romans 3:23
difalkner is offline
post #3 of 12 (permalink) Old 06-07-2018, 03:05 PM
Welcome Lewis..
that router has speed control but isn't know for having issues.... try dialing in different speeds...
the brushes just may be the issue..
w/ a 5 year warranty you my be able to have it taken care of w/o charge...
File Type: pdf Diagnosing Electric Power Tools 101.pdf (386.8 KB, 22 views)
post #4 of 12 (permalink) Old 06-07-2018, 03:20 PM
I had a Milwaukee router a few years ago ,and they are a very good router. I bought it new and never had any problems. I hope you get yours running good again. Take Sticks advise and contact their Custromer Service.
https://www.milwaukeetool.com/contact
Herb Stoops is offline
post #5 of 12 (permalink) Old 06-08-2018, 07:36 AM
Grangur's Avatar
First Name: Richard
Hi Lewis, I don't know that router but I suspect it has a thermal cut-out and the arching is causing heat to make it cut out.
So, best action is get someone to service it asap.
Grangur is offline
post #6 of 12 (permalink) Old 06-08-2018, 08:54 AM
First Name: Art
I'm guessing that if you decide to take it to a repair shop it will cost you more than a good used one or maybe even a good new one. If as Stick suggested it is under warranty you may get lucky otherwise check out Craigslist or Ebay.
mgmine is offline
post #7 of 12 (permalink) Old 06-08-2018, 11:46 AM
This was a used machine when Lewis got it, and likely has quite a few hours of usage on it. It's likely no longer be under warrantee. If it's brushes, that's not such a big deal and you can look up parts for the make and model. Milwaukee is a good brand so parts and repairs should be available either from the maker or parts suppliers or even local tool repair people. Be sure to read Stick's pdfs!
post #8 of 12 (permalink) Old 06-08-2018, 12:27 PM
MT Stringer's Avatar
Welcome aboard.
MT Stringer is offline
post #9 of 12 (permalink) Old 06-08-2018, 12:33 PM
First Name: Reuel
Default Try cleaning the Armature First
I suspect it is the armature shorted in the gaps by Carbon dusts.
1. Clean with Armature with compressed air then fiber glass pen or fine GLASS paper or strong bamboo toothpicks and air blow again.
2. Replace the Carbon Brushes anyway since they are very Cheap.
I have resurrected my Kress power drill and my powerful small sized Hoover vacuum cleaner (I use for servicing computers onsite) by following those procedures.
Tool I use is ALWAYS - Fiber Glass Pen shown.
Best Regards
Reuel
"The gift of God is eternal life thru Jesus Christ our Lord"
Reuel - means "God's friend" (Heb)
reuelt is offline
post #10 of 12 (permalink) Old 06-08-2018, 05:29 PM
Welcome to the forum. The fact that it comes on makes me think it’s not brushes. Not coming on or running at a reduced speed is more indicative of brush problems. It sounds more like it comes on just long enough for something like a capacitor in a circuit board to heat up. If you are knowledgeable in that area you could try bypassing the soft start and speed control and see if that solves the problem.
Yet another router table build ... JohnBFisher Table-mounted Routing 23 11-13-2014 11:33 AM
Thanks for a great forum tmutchf New Member Introductions 9 03-11-2010 04:43 AM
Hi...new to this forum and need some MAJOR help with a router problem Angelo General Routing 14 05-02-2009 11:54 AM
