painted lumber? - Page 2 - Router Forums
 17Likes
post #11 of 20 (permalink) Old 08-07-2018, 03:14 PM
I did the 7:30AM thing again this morning...got the 2nd coat on before it got too hot on the substrate to apply paint. Then I washed down the window trim (facing South) in prep for painting and a tiny, bright green, tree frog popped out from behind the shutter! .
Hope I didn't harm it with the TSP solution; those guys are really sensitive to chemicals...
Danman1957 and TenGees like this.
DaninVan is offline
post #12 of 20 (permalink) Old 08-07-2018, 03:36 PM
Knothead47's Avatar
Amphibians are the "canary in the coal mine" for the environment. Too small for frog legs.
DaninVan likes this.
John T.
Life is like water-skiing; if you slow down, you go down.
Knothead47 is offline
post #13 of 20 (permalink) Old 08-08-2018, 09:42 AM
sreilly's Avatar
First Name: Steve
Consider the composite boards and forget painting and the like. Power washing rules. I prefer to make my life easier which doesn't include painting, especially painting. I'll leave that to the pros.
-Steve
sreilly is offline
post #14 of 20 (permalink) Old 08-08-2018, 10:09 AM
I got tired of the "every other year" need to strip the old coating and apply new and even paid a "painting company" an extortionate amount to do it the last go around, hoping that it would last longer but no such luck. I gave in and replaced the decking and handrails with "maintenance free" products, and am hoping that this chore is finally behind me. As a plus, my wife loves her new deck, all kinds of brownie points achieved. I still need to replace the lattice work around the underneath, that's been held up by the recent incessant rain and the (happily departed) kidney stone.
I've never had much luck with exterior paint, regardless of brand, and now have all exterior trim wrapped in aluminum except for the basement door which is on my list. I built a storage shed 27 years ago and it's held up well, although needing to be power-washed and repainted every five years or so. It's probably due for another coat, and I'm seriously considering covering it with vinyl siding - at 8' x 12', the cost won't be too bad, probably more cost in the trim pieces than the actual siding - as the T-11 siding is starting to look a little shabby underneath the paint. A possible project for cooler weather though.
JFPNCM, DaninVan and Danman1957 like this.
tomp913 is online now
post #15 of 20 (permalink) Old 08-08-2018, 10:52 AM
First Name: JJ
Would definitely recommend going with a "manufactured" material and just biting the bullet on the cost. Sometime you can get a 12 to 18 month interest free deal at the big box stores to help spread out the cost. You will be thanking yourself many times over when you don't have to touch up or completely redo the what ever finish you would apply to wood material.
Flipsaw is offline
post #16 of 20 (permalink) Old 08-08-2018, 11:16 AM
Danman1957's Avatar
Daninvan,
I remember when I visited you in 2016, you showed me that you were going to re-do the railings. 2 years is not impressive. I have had good results using marine paint, I painted the new plywood floor I installed in my trailer 10 years ago and it is still great. Funny how some of the Tremclad I used on the metal sides is starting to peel !
I am currently building a new section of deck for the new pool we had installed and we are considering painting the railings white with the brown treated wood decking it should look nice. If we do, I'll be buying the marine paint again.
Don't fear your tools, pay attention and respect the tools and avoid injury.
Danman1957 is offline
post #17 of 20 (permalink) Old 08-08-2018, 11:20 AM
Danman1957's Avatar
Tom,
Are your spindles aluminium tubing powder coated ? or ?
post #18 of 20 (permalink) Old 08-08-2018, 11:27 AM
Originally Posted by Danman1957 View Post
Daninvan,
like topside boat paint???
Danman1957 likes this.
Stick486 is offline
post #19 of 20 (permalink) Old 08-08-2018, 03:41 PM
Wasn't me, but sounds like a good idea. A bit pricey though (you get what you pay for I guess).
DaninVan is offline
post #20 of 20 (permalink) Old 08-08-2018, 03:43 PM
Tom,
Powder coated. Went with the dark color based on a article I read that the dark color faded into the background when you looked through them - and it appears to work. Couple things I would do different next time - but then I'm hoping that there isn't going to be a next time.
Router bits for Mortise and Tenon project? windhollowfarm Router Bits - Types and Usage 267 08-29-2018 12:19 PM
My build of a lumber storage cart to get my workshop organized Daniel80 Project Plans and How To 8 06-01-2017 01:18 PM
New to woodworking...where to buy lumber? embo5 Starting Off 14 11-18-2013 10:43 PM
Grading Of Hardwood Timber Gaia Wood Species 23 07-17-2013 04:12 PM
HD and their slim choices of lumber.... Hamlin Lobby 6 07-07-2006 05:16 PM
