Router Forums (https://www.routerforums.com/forum.php)
-   Starting Off (https://www.routerforums.com/starting-off/)
-   -   Used Table Saw Purchase (https://www.routerforums.com/starting-off/137259-used-table-saw-purchase.html)
peterbata 01-04-2019 10:11 AM
3 Attachment(s)
Hello all. My apologies if I am posting this in the wrong section. I am looking at purchasing a used table saw. I am hoping to get your input. I am starting off and have a very limited budget. I realize that there are many factors that go into the purchase of a used item (sight unseen) but I thought that I would run it by you folks anyway.
I cam across 2 table saws that are selling for 100.00 - 125.00
1 - Ryobi Portable Table Saw Model No: RTS21G
2 - Craftsman (Still waiting for the seller to get back to me with the model number)
I am a novice and was wondering what are some of the things that I should be looking for.
Or, is it just a roll of the dice and hope that the item holds up. Even if it is until I can afford a quality machine. I have a small project that I hope to get off the ground soon (Acoustic panels that I mentioned in an unrelated post)
Thank you so much
Peter
DesertRatTom 01-04-2019 10:59 AM
1 Attachment(s)
Buying a cheap saw is unlikely to do you much good. I had a used Ryobe for a couple of days when I first started and immediately put it into recycler. This one is a newer model and might work out for awhile. But read on...
No way most of us will touch a Craftsman tool new or used--no parts available when it breaks. Used table saws are not really that hard to find if you're patient. Hold out for something by Bosch if you can in the portable saw category.
The table saw is the center of any shop. You can replace some of its functions with a circular saw with a clamped-on straight edge and premium blade, but it will never have the precision possible with a decent table saw.
I'd keep looking, including estate sales, online and yard sales. Several people here have found really top notch table saws at estate or garage sales where the sellers really had no idea of the value.
My first decent table saw was a clearance item at Lowes, $300 for a Delta contractor saw, still in the box. Worked for me for several years and now in my Son in Law's garage. My personal view is that an acceptable table saw like the Bosch 4100, is worth saving up, and even a little debt. Buy in haste and regret at leisure.
Hopefully, others will chime in soon with alternatives. Some like the new DeWalt portable contractor saw, but not sure if there are many used ones out there. Be sure the saw you buy will take at least a 6 inch dado blade set. Some have arbors that are too short to accept a set, and you will very quickly need to get a set.
Since you're relatively new to woodworking, I've attached a pdf of an article on the 17 things that accelerated my learning over the past decade or so. Hopefully it will help you avoid some of the costly lessons I learned. It's long but has pictures. Keep it around for re-reading from time to time. Next thing to get after the table saw is a really good dust mask.
JOAT 01-04-2019 11:00 AM
I bought a similar one awhile back, don't recall the brand, but possibly they are all made in the same plant anyway. No stand, and hadn't been used for awhile. But ran fine, and was $35. I've also got a similar Harbor Freight saw I bought new in about '96-97, somewhere a bit over $50, still using it. I looked at some of the big name saws, going for around $300, and a couple, except for the color, were twins of mine. I would say for those prices, for used saws, I would shop around a bit more. Possibly you can find one someone wants to trade. Got me a scroll saw that would normally go for around $100, used, for a $35 flute.
Your dime, you will ultimately have to make the call.
Stick486 01-04-2019 11:16 AM
the Ryobie I wouldn't touch w/ a 100' pole..
table issues..
miter issues...
PITA to use a sled on..
insert issues...
low power..
if the craftsman is belt driven you might be on to something...
their cheapo pulleys are usually an issue...
if it's a 1hp model it's seriously under powered...
1 HP models are marginal power department
if it's direct drive... I'd stay away from that one too...
DesertRatTom 01-04-2019 11:21 AM
You could check out reviews online to help make your choice. Search for Reviews of Ryobe RTS21G. I found what turns out to be a pretty good review of the Ryobe saw at https://electrosawhq.com/ryobi-table-saw-reviews/
At $100, looks to be OK. It is far better built than the one I tossed. If money is really an issue, I'd go for it. And, according to the review, it will take a dado stack. Looking at again, the previous owner at least put a dust catcher on it, which suggests some care was given it by the previous owner.
Stick486 01-04-2019 11:22 AM
I wouldn't take it if was paid to take it gift..
fence issues
table issues..
miter issues...
insert issues...
low power..
hawkeye10 01-04-2019 11:39 AM
The thing about Craftsman is it's going out of business with Sears standing behind it. I took back a half inch ratchet about a year ago that I have had for 30 years or longer. Their tools used to be guaranteed for life now I think it's for a year. There are plenty of places that you can buy tools that are guaranteed for life. There are plenty of good saws out there without buying Craftsman.
peterbata 01-04-2019 11:53 AM
1 Attachment(s)
@Stick486 If you posted this twice does that mean that you wouldn't touch it with a 200' pole. Just teasing!
Thank you all for your input. I really do appreciate it.
The reality is that I have that acoustic panel project that I would like to get started on. Sure, I can wait till the ultimate deal comes along but this has been dragging on for a while. Holidays and all. There is always an excuse I guess.
Or I can go out and spend close to a thousand dollars after taxes on a Bosch 4100-10. Unfortunately, that is not possible for me at the moment.
What I am going to do with the few pieces of woodworking tools that I have picked up after I am done building my panels is another matter. Which is the main reason why I do not want to spend more than I have to in order to complete the work. I have been looking at local classified ads for quite a while. And frankly, there is so little available in the way of decent quality tools. At least in the area that I live in. It's pretty much all the same ad after ad:
People unloading their old tools - Craftsman, B&D, Skilssaw, Delta, etc. For the most part they all seem to have served in some World War.
Not to mention that once the acoustic treatment is finished in my room, there is more audio gear that I will be purchasing soon after. I had even considered renting the tools that I need versus a straight out purchase. The problem with that is that the time that I can dedicate to the completion of my panels may be staggered. So, renting may not be a wise option!
I need more time to think about all this. Sorry about the long-winded post.
Peter
Cherryville Chuck 01-04-2019 12:05 PM
If the Sears has an iron top instead of aluminum I would go with it. I bought a Craftsman like the Ryobi a few years ago. The fence was a problem. It was difficult to line up straight. I had to check every time I moved it to see if it was parallel to the blade which was a PITA. It wouldn't stay put during a cut until I glued some sandpaper to the back clamp. It was under powered but if I took my time I could get past that problem. You can't expect a saw like that to perform like a Unisaw or Powermatic 66.
My first saw was a direct drive 1 hp Sears. The fence was okay and the power was okay but it had an aluminum top and I bent it slightly which means you never get a perfectly straight cut with it. Despite that it still got the job done and may still be going with only one relay replaced in 35 years. I sold it a couple of years ago for $10. When I bought my Unisaw it served as a backup until a friend sold me an old Rockwell for $100. The Rockwell is a pretty good saw. The fence was decent but I had an aftermarket I replaced it with that was even better. The only issue I had with the Rockwell was a short distance past the blade to the back of the table which I improved with a short out feed added on. If you can find one of the old Rockwell Beaver saws in good shape I would go with it and they sold a lot of them back in the day.
peterbata 01-04-2019 12:12 PM
Thank you @Cherryville Chuck . I contacted the woman who is selling the Craftsman. Actually, it used to belong to her father. Sadly, he passed away a few weeks ago. She could not provide me with a model number at the time but she is supposed to get back to me today. I am certain that she won't be able to tell me if the top is iron or aluminum. I would have to go out to see it in person.
Powered by vBulletin® - Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
