Table saw fence - Router Forums
 6Likes
post #1 of 12 (permalink) Old 05-19-2019, 10:23 PM Thread Starter
First Name: Dennis
Default Table saw fence
As I mentioned in another thread, Iís gots me a Delta 36-6000 series for a bargain of a price. Itís a contractor saw with a 24Ē table, and not without its quirks. The biggest one by far is that the rip fence is utter schlock. Not only that I had to take apart & fix the clamp assembly to set the rotating pin right (it was popping out of alignment and the clamp wouldíve crooked and not work as it should), but it also that the fence wonít clamp true square. Ea time I need to make a rip cut, I end up spending time with a caliper to make sure the fence is parallel to the blade. So far the only somewhat quick fix was to screw a strip of HDPE to the fence to reduce the friction.
Iíve been looking into replacing this junk, but couldnít find anything compatible for cheaper than $200. And thatís more than I paid for the saw. My question , therefore, is how you experienced folks deal with these issues and if thereís an affordable solution to this ?
Sent from my iPad using Tapatalk
qulevrius is online now
post #2 of 12 (permalink) Old 05-20-2019, 10:55 AM
Without seeing the mechanism I can’t say if it can be fixed. I bought a cheap Sears that couldn’t be but I have an Excalibur/ Unifence type on a Unisaw that is good but pricey and I have an Accusquare on an old Rockwell that is just as good and not nearly as pricey. Still more than $200 but not a lot more.
post #3 of 12 (permalink) Old 05-20-2019, 12:42 PM
ger21's Avatar
First Name: Gerry
To me, the fence is the most important part of the saw, and if the saw itself is decent, a good fence can make a world of difference.
30 years ago, I put a Vega fence on a Craftsman contractor saw, and used it for many years until I got a new Unisaw.
It was about $275, and worth every penny.
Stick486 and RainMan 2.0 like this.
Ger
www.cncwoodworker.com
ger21 is offline
post #4 of 12 (permalink) Old 05-20-2019, 12:45 PM
RainMan 2.0's Avatar
Exactly the way I feel . I had a 10Ē delta contractors saw with a Biesemeyer fence , and it was just a joy to work with . I learned my lesson from a friend who had a cheaper fence that could drive you to fits
Ok ,I never insulate
RainMan 2.0 is online now
post #5 of 12 (permalink) Old 05-20-2019, 08:39 PM Thread Starter
First Name: Dennis
Without seeing the mechanism I canít say if it can be fixed. I bought a cheap Sears that couldnít be but I have an Excalibur/ Unifence type on a Unisaw that is good but pricey and I have an Accusquare on an old Rockwell that is just as good and not nearly as pricey. Still more than $200 but not a lot more.
As a rule, Iím willing to shell out a decent amount to make life worth living. But lately, Iím forced to do it because otherwise the tools are not performing up to the expectations. For example, I find it nearly impossible to cut a miter runner that wonít have a play and wonít require additional sanding to fit right. I am actually opting for aluminum t-tracks that cost ~$9 per 24Ē, but perform admirably. Itís just difficult to digest the fact that a vital accessory can cost twice as much as a tool itís intended to be used with.
post #6 of 12 (permalink) Old 05-20-2019, 08:53 PM
ger21's Avatar
First Name: Gerry
It’s just difficult to digest the fact that a vital accessory can cost twice as much as a tool it’s intended to be used with.......................
It’s a contractor saw with a 24” table
What you have is not what most call a "contractors" saw. You have a jobsite or benchtop saw.
What's commonly called a "contractor's saw" is a full size saw, with a cast iron top, with a belt driven arbor and induction motor. There's a night and day difference between a jobsite saw and a contractors saw.
To be honest, I've never seen anyone put a really good fence on a jobsite saw, and I'm not even sure you could without a lot of modifications.
Generally, anyone buying a $200-$350 fence is putting it on a saw that costs much more.
Ray Newman, radios and DaninVan like this.
Ger
ger21 is offline
post #7 of 12 (permalink) Old 05-20-2019, 09:28 PM Thread Starter
First Name: Dennis
Apologies for the confusion. I always thought the difference is between a bench top to contractorís to hybrid to cabinet saws.
Thatís exactly my point, I cannot justify spending twice the cost of the tool on an accessory. Nor Iíll be able to justify it to the wife. Thatís why I was asking whether thereís an affordable fix or a DIY alternative.
post #8 of 12 (permalink) Old 05-20-2019, 09:57 PM
Mule Cabinetmaker - Carpentry Tools for Carpenters that Need Precision & Reliability! Like I said, not much more.
post #9 of 12 (permalink) Old 05-21-2019, 07:55 AM
First Name: Mark
It is nice to have a saw with the functioning rip fence but when I was running my craftsman hybrid tablesaw, I developed and used something like the following to set the fence. It took the independent measurements out of the process.
https://www.routerforums.com/jigs-fi...ing-guide.html
qulevrius likes this.
FreeTime is offline
post #10 of 12 (permalink) Old 05-21-2019, 08:31 AM
ger21's Avatar
First Name: Gerry
You can find a lot of DIY fences with Google.
Ger
ger21 is offline
Fold down router table Gaffboat Table-mounted Routing 21 09-09-2018 06:41 PM
Which aluminum channels to secure fence to table RainMan 2.0 Table-mounted Routing 125 07-06-2015 11:13 AM
Kreg Router Table and Fence jeffk Table-mounted Routing 25 10-14-2011 06:25 PM
DIY Table and fence - finished! JohnWP Table-mounted Routing 6 01-30-2011 08:39 AM
