Half Ball Cup Formation Method? - Page 2 - Router Forums
 6Likes
post #11 of 15 (permalink) Old 11-22-2019, 09:39 AM
roxanne562001's Avatar
First Name: Roxanne
Welcome to the forum. If you drill the hole with an adjustable circle cutter aka fly cutter in a drill press then use a round over bit with a pilot bearing to form the rounded edge. Then sand to get the exact fit you want.
OutoftheWoodwork and Nickp like this.
roxanne562001 is offline
post #12 of 15 (permalink) Old 11-23-2019, 07:00 AM
Country: South Africa
First Name: Biagio
Lee Valley has a pneumatic ball nose sanding drum, which looks almost purpose-designed for the sanding part of this job.
Biagio is offline
post #13 of 15 (permalink) Old 11-23-2019, 08:24 AM
Two mating flats made w/ a fostner bit...
as soon as the rim of the bit touches the ball stop drilling...
Stick486 is offline
post #14 of 15 (permalink) Old 11-23-2019, 10:22 PM
First Name: Biagio
MSAL,
I think you are on the right track. 40mm Forstner bits are fairly common. A cylindrical 40mm flat-bottomed hole, 20mm deep, will hold your ball exactly as you want it, with no complicated sanding, etc. The fact that it is not a half-round cup hole, will not be visible. If you want the ball to rotate in the hole, so much the better - only one friction point at the bottom of the hole. If you do not want it to rotate, one dab of hot-melt glue at the same location.
Interesting how one gets to overthink situations.
Biagio is offline
post #15 of 15 (permalink) Old 11-24-2019, 12:01 AM
Originally Posted by Biagio View Post
MSAL,
you could use the point from the fostner bit to accurately install a dowel, dowel screws or a blind nail...
Stick486 is offline
