Half Ball Cup Formation Method? - Router Forums
 6Likes
post #1 of 15 (permalink) Old 11-21-2019, 11:33 AM Thread Starter
First Name: MSAL
Default Half Ball Cup Formation Method?
Newbie here.
I have a project where I want to form a half ball rounded hole in a 60 x 60 mm piece of wood.
This will hold a 40mm diameter ball half way within the wood and half protruding.
I want the ball to fit snugly within so that it cannot move.
I cannot seem to find a drill or router bit for this task.
Is there an easy way to form this hole?
Thanks in advance.
MSAL
Mr.Shing-A-Ling is offline
post #2 of 15 (permalink) Old 11-21-2019, 11:57 AM
https://www.freudtools.com/search?h=1
Stick486 is offline
post #3 of 15 (permalink) Old 11-21-2019, 01:07 PM Thread Starter
First Name: MSAL
Stick486
Thanks for the reply, but your link just goes to a blank page, no product?
post #4 of 15 (permalink) Old 11-21-2019, 01:19 PM
OutoftheWoodwork's Avatar
First Name: Barb
Hey Newbie:
Would love to know who I'm talking to; can you change the N/A for your name? As for creating your crater, I would be one to trace the ball, and using a round nose bit, slowly work at it. But I'm a improviser, like some of the others on here.
thomas1389 likes this.
Barb
Get your facts first, then you can distort them as you please.
Mark Twain
There cannot be a crisis next week. My schedule is already full.
Henry A. Kissinger
If you choose to poke at a bee hive, be prepared to get stung.
OutoftheWoodwork is offline
post #5 of 15 (permalink) Old 11-21-2019, 01:41 PM Thread Starter
First Name: MSAL
Originally Posted by OutoftheWoodwork View Post
Hey Newbie:
Thanks Barb
I can see that a Round Nose Cove router bit would do the job, but I'm struggling to find a bit 40mm in diameter? I've looked on-line generally and on ebay. I thought this would have been easy!
post #6 of 15 (permalink) Old 11-21-2019, 01:55 PM
Originally Posted by Mr.Shing-A-Ling View Post
Stick486
https://www.freudtools.com/products/18-138
Stick486 is offline
post #7 of 15 (permalink) Old 11-21-2019, 07:48 PM
He's looking for an exact fit Stick and I'm with him, I know of no manufacturer making a 40mm round nose bit. In Imperial it would be a little more than 1 17/32".
MSAL you can get Whiteside Manufacturing to make you one but it would be pretty pricey or maybe if you can find one that's 3/4" radius it might be close enough. The ball would sit a little higher than halfway but not much.
post #8 of 15 (permalink) Old 11-21-2019, 07:50 PM
Get close...
Sand to fit...
Stick486 is offline
post #9 of 15 (permalink) Old 11-22-2019, 08:23 AM
sreilly's Avatar
First Name: Steve
Get close...
Sand to fit...
That was my thought. I mean usually it takes a bit more that just a single pass to get the perfect fit on most anything unless you plan on using the bit sizes you have and work from there. Sand paper is perfect for those small adjustments.
sreilly is offline
post #10 of 15 (permalink) Old 11-22-2019, 08:42 AM Thread Starter
First Name: MSAL
Thank you for the replies and information.
Since a 40mm radial bit will be bespoke and costly, I'm now thinking of forming the hole with a 40mm Hinge Hole Boring Cutter Wood Drill Bit Flat which are readily available. It won't be conical round, but should do what I want it to do.
Thanks all.
MSAL
