Shelf Pin Cutout? - Router Forums
 11Likes
  • 1 Post By PhilBa
  • 4 Post By gdonham1
  • 3 Post By Stick486
  • 1 Post By sreilly
  • 2 Post By Cherryville Chuck
post #1 of 7 (permalink) Old 01-14-2020, 06:11 PM Thread Starter
wwian's Avatar
First Name: Ian
Question Shelf Pin Cutout?
Hey Folks!
I'm working on some adjustable shelves for my son's desk. I have the Kreg jig to drill the pin holes. But I want to add a "cutout" (like in the photo below) in the bottom of each shelf for it to rest on the pin to try to stop them from sliding out. Any suggestions on how to go about that?
Dad. Geek. Woodworker. Coffee then talkie. Salesforce Neophyte. Into smart people, provocative thinking & fresh perspectives. Ambitious dreamer. A human. Being.
wwian is offline
post #2 of 7 (permalink) Old 01-14-2020, 07:47 PM
PhilBa's Avatar
First Name: phil
Originally Posted by wwian View Post
Hey Folks!
Do you have a router bushing set? Easy enough to make a simple template out of 1/4" plywood or MDF. Use a router bit that is the same diameter as the pins and set the depth to the diameter as well. Make two slots the correct distance apart in the template and you will have perfect spacing each time. If you want round bottomed slots like in the picture, you can use a ball nose bit of the correct diameter.
Cherryville Chuck likes this.
Visit my shop website.
PhilBa is offline
post #3 of 7 (permalink) Old 01-14-2020, 10:16 PM
gdonham1's Avatar
First Name: Guy
They do make L brackets in both 5mm and 1/4" that have a hole to put a screw in the bottom of the shelf. Most shelves once adjusted are not moved. However if you want to move the shelf just remove the screw, move the shelf and replace the screws.
gdonham1 is offline
post #4 of 7 (permalink) Old 01-15-2020, 05:00 AM
my vote goes to Guy...
his method is easiest and about bullet proof..
the L style is less likely to pivot in the drilled hole..
JFPNCM, roxanne562001 and TenGees like this.
post #5 of 7 (permalink) Old 01-15-2020, 08:23 AM
sreilly's Avatar
First Name: Steve
I've always used the L brackets but have to admit most of mine are loaded shelves and there was no need for the screws.
DaninVan likes this.
sreilly is offline
post #6 of 7 (permalink) Old 01-15-2020, 11:22 AM
My vote also for the 'L' style, if you use drilled holes. My preference is the more 'industrial' look with rebated pilasters and clips.
Not everyones' taste, i know...
https://www.thehardwarehut.com/shelf...s_pilaster.php
Brushed Aluminum is my first choice.
With books on the shelves they're basically invisible in any case.
I should mention that clips can be add with non-slip pads on the sliding surface...very effective.
DaninVan is offline
post #7 of 7 (permalink) Old 01-15-2020, 12:13 PM
I use these from Lee Valley: https://www.leevalley.com/en-us/shop...ts-and-sleeves With the flat top the shelves are pretty stable on don`t move around much. I use these sleeves in the carcass which hide any chip out from drilling the holes: https://www.leevalley.com/en-us/shop...ts-and-sleeves. Then you need this tool for setting the sleeves: https://www.leevalley.com/en-us/shop...-setting-punch. A little more involved process but it gives a really nice look when finished.
TenGees and RainMan 2.0 like this.
