PRL-V2 Router Lift - Router Forums
post #1 of 9 (permalink) Old 03-09-2010, 12:38 AM Thread Starter
First Name: David
Default PRL-V2 Router Lift
I've got a PC7518 & PRL-V2 router lift. So far, so good.
I'm building a cabinet to set the top onto. Still good, lots of learning on this first project, but still good.
I need to get the router lift mounted in the top, which, by the way, is a double layer of 3/4" Birch ply. I'm confusing myself on this part of it. How do I
  1. Cut the hole for the lift to fit into, &
  2. Route the edge for the lip upon which the lift will sit &
  3. What is the radius on the corner of the lift???
I've got a hand-held plunge router, another fixed base router mounted in a very cheap stamped steel benchtop router table, and a guided straight bit. I guess I need a template - Tracing the plate onto a piece of 1/2" ply would probably do the trick.
Any pointers on doing it myself?
Or, should I just take the lift and the tabletop to a counter mfgr here in San Antonio so THEY can laminate some formica or wilsonart on top, and have them cut the hole & route the edge??? That will cost $$$, and I'll lose the satisfaction of saying to myself "I did ALL that!"
DarkFlame is offline
post #2 of 9 (permalink) Old 03-09-2010, 12:39 AM Thread Starter
First Name: David
One other question, what is the "brake" used for on the lift? I mean, it doesn't STOP the bit from turning, does it?
Thanks!
David
post #3 of 9 (permalink) Old 03-09-2010, 12:42 AM
Dr.Zook's Avatar
First Name: Dave or "Doc"
Welcome to the RouterForums David. Glad to have you as a member.
Dave
the "Doctor"
Dr.Zook is offline
post #4 of 9 (permalink) Old 03-09-2010, 07:53 AM
On vacation
First Name: Joe
Thanks!
David
Congrats on the PRL-V2, the best router lift made.
The brake is used to insure that the adjustment wheel does not move due to vibration during use. It does not affect the operation of the router.
jmg1017 is offline
post #5 of 9 (permalink) Old 03-09-2010, 04:47 PM
TwoSkies57's Avatar
David..
Gently turn the set screw when locking down the brake.. it don't take much!!!
and yep, best lift on the market *S*..
I do believe its a 3/4" radius..verify first..
TwoSkies57 is offline
post #6 of 9 (permalink) Old 03-14-2010, 09:59 AM Thread Starter
First Name: David
Talking about the corner radius, here's a picture ...
I have a 1 3/8" Forstner bit, which would be 11/16" radius. If this is 3/4" (12/16"), then I need to buy a 1 1/2" Forstner bit.
I don't have ANY PROBLEM buying a 1 1/2" Forstner bit, but I usually buy on an "as needed" basis, not just to accumulate tools.
I figure extra sets of eyes will be a big help.
So, tell me, is this a 3/4" radius, or 11/16" radius.
post #7 of 9 (permalink) Old 03-14-2010, 06:32 PM
TwoSkies57's Avatar
According to Incra.. its a 0.750 (3/4") radius...
post #8 of 9 (permalink) Old 03-19-2011, 10:51 PM
don_chr's Avatar
First Name: Don
I recently purchased the PRL-V2 for use with a PC 7518 router. The course adjustment seems to be sticky making it hard to get the course bit hieght I'm shooting for. Also, sometimes after I take the course adjustment tool out the mechanism it does not lock down the lift height. Finally, the fine adjustment works okay for lowering the router, but does not raise the router. The thumb wheel raises the threaded rod in the lift like it is supposed to, but the threaded rod does not seem to be locked into the mechnism. Can any of you PRL-V2 users give me any pointers?
Thanks,
Don
don_chr is offline
post #9 of 9 (permalink) Old 03-20-2011, 09:01 PM
don_chr's Avatar
First Name: Don
All, An update on my sticky lift issue. I received a quick reply back from Mark at Incra with some steps for troubleshooting the sticky movement. I ended up having loosen the two guide posts and reseat them. This seems to have fixed the issue and the lift is now working very smoothly.
Don
Thanks,
Don
don_chr is offline
New Router my way reible General Routing 21 12-08-2018 12:06 PM
Router lift for Freud FT3000vce? Tuthmose Table-mounted Routing 12 12-10-2010 11:35 PM
Hello DPugmire New Member Introductions 5 11-08-2010 07:29 AM
Shop made router lift Noob Table-mounted Routing 7 01-19-2010 02:02 AM
Router Lift for the Skil 8125? MajMayAL Table-mounted Routing 3 11-28-2009 03:56 AM
