Help please router direction - Router Forums
post #1 of 14 (permalink) Old 08-08-2012, 11:40 AM Thread Starter
Default Help please router direction
Hi All.
I am a little bit confused, if I am using my router correctly.
I understand that you go in the oppersite direction, to the rotation of the cutter, (or that's what I believe to be correct).
The base plate shows I think the direction of the cutter rotation, so therefore I need to move the router in the oppersite direction.
Is that correct ?
Many thanks
Dave.
rebel60 is offline
post #2 of 14 (permalink) Old 08-08-2012, 01:41 PM
The Warthog's Avatar
First Name: Roger
Think of it this way, if you have both hands on the handles, the part of the bit closest to your right hand will be moving toward you. That should help you visualize the rotation of the bit, so you are always moving the router so the bit is going forward on the side that is doing the cutting, against the cutter's motion.
If you are making a dado or a groove, use a straightedge, and move the router as if you were cutting a shape on the straightedge.
This helps me get through my routing day.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
post #3 of 14 (permalink) Old 08-08-2012, 04:34 PM Thread Starter
Cheers for that Rodger.
I was doing it right
rebel60 is offline
post #4 of 14 (permalink) Old 08-08-2012, 05:36 PM
Hi Rebel - I always use a "right hand rule of thumb". Make a fist with your right hand, extend your index finger and thumb. Now, turn your hand palm down with your thumb pointing to the edge you want route or guide against and your index finger will point toward your correct direction of travel.
John Schaben
jschaben is offline
post #5 of 14 (permalink) Old 08-09-2012, 05:48 AM
First Name: Peter
Thank you from me too for that handy hint.....cheers, crowie
crowie is offline
post #6 of 14 (permalink) Old 08-09-2012, 08:50 AM
First Name: Frank
This will not help in Routing. But when I was very young, my father taught me to use a right hand rule of thumb when backing up a trailer. You place your hands on the bottom of the steering wheel and the way the the thumbs move left or right is the way the trailer behind you is going to move that direction. No help, I know, just a rule of thumb.
Tagwatts1 from Utah
Tagwatts1 is offline
post #7 of 14 (permalink) Old 08-09-2012, 10:53 AM
A picture is worth a thousand words.
Name:	Feed direction.JPG
post #8 of 14 (permalink) Old 08-09-2012, 06:11 PM
First Name: Tim
Hi Dave. As you look down at the router in your pic, the bit will be turning clockwise, just like the arrow points. If you were to be using a round over bit, for instance, with a bearing to guide it, and the work piece was on the other side of the router, you would go from left to right, so that the cutter was turning into the work. If you were dressing the entire circumfrence of a board that way, the router would be moved in a counter-clockwise direction all the way around it.
DrNeon is offline
post #9 of 14 (permalink) Old 08-09-2012, 09:17 PM
Thumbs up
Ideal explanation, Mike.
Where did you get the pictures?
Sydney, Australia
jw2170 is offline
post #10 of 14 (permalink) Old 08-09-2012, 10:24 PM
The first photo was an Email tip from one of the magazines, the second photo is from one of the router manuals but I don't remember which one.
Dust Evacuation on Router Table Guitarman1 Table-mounted Routing 15 04-29-2013 01:51 AM
router direction CANMIL General Routing 7 08-09-2012 10:35 AM
Already Problems neuschu New Member Introductions 11 12-15-2009 07:01 AM
Router table or Plunge routing template tom Guide Bushings and Templates 15 04-14-2009 02:45 AM
