by-passing steam bending ! - Router Forums
post #1 of 7 (permalink) Old 08-20-2012, 07:32 PM Thread Starter
First Name: Dennis
Default by-passing steam bending !
I had routed a 1/8 " circular groove that I wanted to bend a piece of oak to inlay in it. After some messing around with steam bending it I gave up --so much trouble for such a little job.
I bent it applying DRY heat with my heat gun and bent it around a coffee can held in place by a bunch of clamps. It worked.
Dennisefl is offline
post #2 of 7 (permalink) Old 08-21-2012, 06:46 AM
First Name: Art
Sounds like a good idea I wonder if it will work on other kinds of wood.
mgmine is offline
post #3 of 7 (permalink) Old 08-21-2012, 07:49 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
Decaf or regular?
OPG3
Tweak everything!
OPG3 is offline
post #4 of 7 (permalink) Old 08-21-2012, 08:01 AM
Guest
First Name: Robert
Good thinking Dennis, and I have a question.
Was the oak an older dry piece or green fresh cut?
57759 is offline
post #5 of 7 (permalink) Old 08-21-2012, 08:17 AM
TRBaker's Avatar
First Name: Troy
A common misconception is that it is steam that causes the wood to bend (or the water in it), when in reality it is the heat. Steam has always been used because the boiling temp of water is 212 degrees and the amount of heat needed to bend the wood is 200 degrees. The steam has always offered an easy way to have controled heat, so the wood doesn't burn, and the desired minimum temperature is achieved, but you then have to deal with the warpage. Good one, Dennis. Thanks for sharing this with us.
Troy
TRBaker is offline
post #6 of 7 (permalink) Old 08-21-2012, 12:35 PM
Phil P's Avatar
First Name: Phil
Hi Art
Don't try it with white (air dried) beech - it will go pink, permanently.
Actually 1/8in (3.2mm) thick will bend easily without any form of heating providing the radius isn't too extreme
Regards
Phil
Phil P is offline
post #7 of 7 (permalink) Old 08-27-2012, 11:00 AM Thread Starter
First Name: Dennis
Default no steam
It was an old piece of scrap wood. I'll try larger pieces and other type of wood as required. Dennis
Steam bending Mike Tools and Woodworking 17 02-10-2014 01:29 AM
Steam bending bobhuerbsch New Member Introductions 11 05-21-2012 10:32 AM
Bending small strips of wood - boiling water? bobbotron Starting Off 2 07-25-2011 06:00 AM
Laminate bending tips for strip creation bobbotron Starting Off 2 06-11-2011 03:37 PM
Tips On Bending Wood PROWOODWORKER0978 Starting Off 2 06-16-2008 11:31 PM
