face gluing HPL sheet to plywood? - Router Forums
post #1 of 4 (permalink) Old 10-11-2012, 08:37 AM Thread Starter
mikeoleary's Avatar
Country: Thailand
Default face gluing HPL sheet to plywood?
I am building a table saw extension. The material I got is 1/4 inch solid phenolic that is faced on both sides with matte finish HPL.
I want to face glue this material to 3/4 inch plywood. What is the right kind of glue to use to bond the HPL to the plywood?
mikeoleary is offline
post #2 of 4 (permalink) Old 10-11-2012, 12:10 PM
kp91's Avatar
First Name: Doug
Mike,
If I had to take a guess, I would scuff up one side of the phenolic panel to get rid of the sheen and then use contact cement. I don't think you'll get a good bond with any adhesive without really getting through the protective layer on the laminate.
1 John 1:9
Fredericksburg, VA
kp91 is online now
post #3 of 4 (permalink) Old 10-12-2012, 10:32 AM
giradman's Avatar
First Name: Dave
Hi Mike - as suggested above, the double-sided HPL may not have been the best choice? I usually use contact cement (non-inflammable products that clean up w/ water are now available) - I've bonded melamine, formica, & tempered fiberboard to plywood successfully w/ this material, but all had an absorbent backing.
The HPL as is would present a problem, and the solution suggested, i.e. scuffing up one surface may be your only choice, unless another poster offers a better option?
Regardless, if you do scuff up a surface and you have enough material you might want to do a test bonding before proceeding. Good luck - Dave
giradman is offline
post #4 of 4 (permalink) Old 10-13-2012, 05:43 AM Thread Starter
mikeoleary's Avatar
Country: Thailand
Thanks for the advice, guys. Scuff and contact cement it will be!
Very nice plywood at Home Depot JimInWoodstock Portable Routing 22 05-06-2012 06:23 AM
"Leg Up" Table Saw Panel Lifter System doc_cj Tools and Woodworking 5 01-23-2012 12:43 AM
Best method to band plywood without tear out Slomoe Router Bits - Types and Usage 8 02-26-2011 10:06 AM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Baltic Birch Plywood Issue - Please Advise Plywoodny Wood Species 17 10-20-2009 01:46 PM
