Pitch Removal Methods? - Router Forums
post #1 of 20 (permalink) Old 10-29-2012, 02:25 PM Thread Starter
Gaia's Avatar
First Name: Peter
Default Pitch Removal Methods?
Methods for removing older,dried out pitch from a circular saw blade range from using Simple Green Pro HD cleaner to soaking in strong black coffee.
What methods do other members use?
Cheers.
Gaia is offline
post #2 of 20 (permalink) Old 10-29-2012, 02:30 PM
Hi
I just buy a new blade,they are only a buck or two...in the states
Cheers.
post #3 of 20 (permalink) Old 10-29-2012, 02:46 PM
Gene Howe's Avatar
First Name: Gene
I use 409 and a brass brush.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #4 of 20 (permalink) Old 10-29-2012, 05:24 PM Thread Starter
Gaia's Avatar
First Name: Peter
Ok thanks, I've read some people use carburetor cleaner which is cost effective. Though might be issues with the carbide in the blade. Like using oven cleaners can cause.
Gaia is offline
post #5 of 20 (permalink) Old 10-29-2012, 05:46 PM
Gene Howe's Avatar
First Name: Gene
I've used oven cleaners....the kind that do not require heat....with no problems. The guy who sharpens my blades claims to have a system for determining the integrity of the carbide and he never commented on my blades. But, because 409 is cheaper, that's what I use now.
BTW, the oven cleaner did remove the "shiny" coating and the red (teflon?) on some of my blades.
Gene Howe
Snowflake, AZ
post #6 of 20 (permalink) Old 10-29-2012, 07:27 PM
First Name: Earl
Cheers.
Of the methods proffered thus far, i'm thinking this one would taste the best!!
Look out St*****ks!!
greenacres2 is offline
post #7 of 20 (permalink) Old 10-30-2012, 06:48 AM
Wildwood's Avatar
Country: South Africa
First Name: Rob
Peter, what works for me is household ammonia - I use a large frisbee that accommodates the blade, and an old toothbrush, and it works really fast.
Wildwood is offline
post #8 of 20 (permalink) Old 10-30-2012, 08:26 AM
I use and highly recommend Trend Tool and Bit clener. This easily removes old resins and is also the best rust removal solution I have found.
Name:	Tool and bit cleaner.jpg
post #9 of 20 (permalink) Old 10-30-2012, 09:01 AM
JOAT's Avatar
First Name: Theo
Kerosene, and a rag.
JOAT is offline
post #10 of 20 (permalink) Old 10-30-2012, 09:27 AM
Contributor of the Month
OPG3's Avatar
First Name: Otis
I have been using WoodCraft's "Gum & Pitch Remover" to my satisfaction for router bits and sawblades. Unlike Mike's method (which is non-corrosive), I would caution against the use of ammonia - as it is highly corrosive. If you solve one problem and create another you have not moved forward, IMHO.
OPG3
Tweak everything!
OPG3 is offline
pitch removal tkinor Tools and Woodworking 1 01-15-2012 11:34 AM
number of methods adjusted allthunbs General Routing 0 06-24-2010 03:42 PM
m12vc spring removal irexx Table-mounted Routing 2 05-19-2010 08:20 PM
Paint Removal from Oak and Oak Ply rh111 The Finishing Touch 7 08-20-2006 08:18 AM
